Crashtd420 Posted November 9, 2023 Report Share Posted November 9, 2023 12 hours ago, banzai510(hainz) said: I have a Schneider in my 521 and its a 460 lift 260 /270 duration I think. with just a Weber DGV Personanlly I think that should be stock on a L motor. Isnt anything special. Its was was avail at the time I think I'm using the same cam.... I liked the power range its ment for... I have another used cam I have debated on sending out for a more aggressive grind... 1 Quote Link to comment
datzenmike Posted November 9, 2023 Report Share Posted November 9, 2023 The stock cam is 248 duration but I doubt this is measured at 0.050" lift like all after market cam grinders. I suspect it's more like 220? Stock lift is 0.413" on the L20B cam. 1 Quote Link to comment
banzai510(hainz) Posted November 9, 2023 Report Share Posted November 9, 2023 On 11/8/2023 at 6:11 AM, Tonellius_620 said: if I’m lucky, I’m hoping to push 102 hp I read somewhere a SSS L18 with dual SU carbs was 77hp to the ground 1 Quote Link to comment
Tonellius_620 Posted November 10, 2023 Author Report Share Posted November 10, 2023 2 hours ago, banzai510(hainz) said: I read somewhere a SSS L18 with dual SU carbs was 77hp to the ground Talk about major horsepower. I am bummed they’re not that beefy but it’s my first build and these motors are easy to work on. Quote Link to comment
datzenmike Posted November 10, 2023 Report Share Posted November 10, 2023 115 PS for the L18SSS. PS is a metric HP equal to 113 HP. Dual SUs and 9.5 compression with a closed chamber 219 head. The L16SSS was 100PS This is likely a gross or brake HP measurement not allowing for drive train losses of around 17%. 113HP would be around 93 at the wheels? about the same an an L20B at the wheels? 1 Quote Link to comment
Stoffregen Motorsports Posted November 10, 2023 Report Share Posted November 10, 2023 After may years dynoing blueprinted L16s for SCCA ITC racing, we figured that the "96hp" advertised was flywheel horsepower, no air pump and SU carbs. So basically SSS form. 1 Quote Link to comment
