second chance Posted November 24, 2023 Author Report Share Posted November 24, 2023 So I did a bit more digging, I found a shadbolt 721 stamp on the cam. What application would suit this cam? 721 Profile: (purported to be a copy of Racer-Brown #391-R, pg. 54 of the later Steve Smith book.) 306 degrees duration (45-81-81-45) Overlap: 90 degrees! (yeowch!, that's racy!) Lift: 0.582” at the valve Cam oiling spray bar MUST be used, along with max effort valve springs, and maybe even lightweight spring retainters Quote Link to comment
datzenmike Posted November 24, 2023 Report Share Posted November 24, 2023 That's full on racing cam I'd just forget about it or sell it. Stock is 2480 and 0.413" lift. Stock overlap is about 30 degrees. 90 must be a miss print. Quote Link to comment
second chance Posted November 24, 2023 Author Report Share Posted November 24, 2023 11 hours ago, datzenmike said: That's full on racing cam I'd just forget about it or sell it. Stock is 2480 and 0.413" lift. Stock overlap is about 30 degrees. 90 must be a miss print. Thanks, any idea where the best place would be to sell the cam? Looks like I won't be needing it. Quote Link to comment
Stoffregen Motorsports Posted November 24, 2023 Report Share Posted November 24, 2023 Off the shelf cams have a couple downsides to them. First of all, most off the shelf cams have profiles dating back decades. Second is, they are pretty generic. Why is a modern profile more appealing? Because things have changed in the Datsun L series world. Much has been learned and the cams now days can be bigger while offering more driveability, better idle and less wear on valvetrain components. Why is a generic cam less appealing? Because it's a one size fits all cam. If you want a cam tailored to your engine and driving style, these generic cams are not always the best choice. My suggestion - pick up the phone (yes, phone) and call someone who builds Datsun engines and get a cam from them. The go-to guys I know are Rebello and Ermish, but there are other Datsun engine builder out there. Quote Link to comment
second chance Posted November 24, 2023 Author Report Share Posted November 24, 2023 6 minutes ago, Stoffregen Motorsports said: Off the shelf cams have a couple downsides to them. First of all, most off the shelf cams have profiles dating back decades. Second is, they are pretty generic. Why is a modern profile more appealing? Because things have changed in the Datsun L series world. Much has been learned and the cams now days can be bigger while offering more driveability, better idle and less wear on valvetrain components. Why is a generic cam less appealing? Because it's a one size fits all cam. If you want a cam tailored to your engine and driving style, these generic cams are not always the best choice. My suggestion - pick up the phone (yes, phone) and call someone who builds Datsun engines and get a cam from them. The go-to guys I know are Rebello and Ermish, but there are other Datsun engine builder out there. Thanks but I'm not specifically looking for a different cam.... I literally inherited this cam yesterday and was wondering what it was or the application it was ground for. I have no problem calling shops to get what I need but I don't like wasting anyone's time. I figured the forum was a good start, guys have been great on here answering questions as time permits. I know know what I have now, next step is going to be finding someone that can use it. 1 Quote Link to comment
datzenmike Posted November 24, 2023 Report Share Posted November 24, 2023 Start here, maybe someone will suggest someone. may not even be a member just someone perusing the forum. https://ratsun.net/classifieds/category/6-datsun-parts/ 1 Quote Link to comment
Rat-a-tat-Dat Posted November 26, 2023 Report Share Posted November 26, 2023 Bystander question, curious to know if these L20B engines are prone to head gasket failures? I'm on my second since procuring this vehicle. Quote Link to comment
Draker Posted November 27, 2023 Report Share Posted November 27, 2023 9 hours ago, Rat-a-tat-Dat said: Bystander question, curious to know if these L20B engines are prone to head gasket failures? I'm on my second since procuring this vehicle. no, they’re not. Probably a warped head or engine deck, or cooling is not sufficient. 1 Quote Link to comment
datzenmike Posted November 27, 2023 Report Share Posted November 27, 2023 Agree. It's not a significant problem on L series engines and seems to be mostly on Z24 blocks but is preventable. If the L series has been over heated it can cause the head to 'warp'. I had a head given to me, and no wonder. When I checked it, it had a high spot 0.015" or pucker right between cylinder 2 and 3. To check you need a very good straight edge laid diagonally across the length in an X and try to slide a feeler gauge anywhere under it. Nissan allow up to 0.004" of warp or about two thicknesses of newspaper. This can be sealed by the head gasket but less is best. Mine was almost 4 times the allowable limit. Head and block surfaces should be spotlessly clean for best results. Do NOT use any sealers or gasket coatings this isn't the '50s and gaskets today are very good. Make sure the head bolts are clean and undamaged, they are totally re-usable. Clean the threads out in the block also. R A D 7.......8 3......4 1.......2 5......6 9.....10 This is the tightening pattern, more or less tighten from the middle outward. Do this in 3 stages. First to 20 ft lbs, then 40 ft. lbs. and finally 60 ft. lbs. Use a good torque wrench. The head gasket does not require it to be re-torqued later after a few runs but if you feel the need loosen one bolt and immediately tighten to 60 ft. lbs. Only when this bolt is tight do you move to the next bolt. Using this method you can do in any order you like. With the rockers out I pulled the head back and forth on a large sheet of glass covered with 80 grit sand paper. Finished with 150 grit. Took about 45 min. Or if you have time a machine shop can mill it flat. Quote Link to comment
Rat-a-tat-Dat Posted November 28, 2023 Report Share Posted November 28, 2023 I don't want to high jack this thread and go on about my issues so should I start a new thread or just add my questions to my existing project? Quote Link to comment
second chance Posted November 28, 2023 Author Report Share Posted November 28, 2023 19 minutes ago, Rat-a-tat-Dat said: I don't want to high jack this thread and go on about my issues so should I start a new thread or just add my questions to my existing project? If you want input from the wider community you might want to start your own thread. Quote Link to comment
Rat-a-tat-Dat Posted November 28, 2023 Report Share Posted November 28, 2023 Great! thanks. For those reading this, I have continued my conversation on my Datto Project. Cheers 2 Quote Link to comment
