Dats_Mandersun_408 Posted September 13 Report Share Posted September 13 I got new octane lights and they worked for a little bit then never came on a gain. the dash lights worked and the side lights but no low beam or headlights. I took the break light fuse and replaced the blown out fuse and they worked for just about 5 minutes and then it blew out too. Do I need a higher amperage? or is it some other wiring issue, thanks! Quote Link to comment
thisismatt Posted September 13 Report Share Posted September 13 You need to put in dedicated new headlight wiring with relays to give the new lights power directly from the battery/alternator. The stock 521 wiring can not handle much draw over stock, especially considering all the current goes through the headlight switch. Use the existing wiring to trigger relays which will connect the new lights directly to the battery. 2 Quote Link to comment
Crashtd420 Posted September 13 Report Share Posted September 13 As a side note never put a bigger fuse in than required.... 1 Quote Link to comment
datzenmike Posted September 13 Report Share Posted September 13 11 hours ago, thisismatt said: You need to put in dedicated new headlight wiring with relays to give the new lights power directly from the battery/alternator. The stock 521 wiring can not handle much draw over stock, especially considering all the current goes through the headlight switch. Use the existing wiring to trigger relays which will connect the new lights directly to the battery. THIS. I assume they are halogen? They draw more current than the stock tungsten filament lamps. Dedicated wiring with proper fuses will allow them to run at full brilliance. The last think you want are the lamps shutting off while driving. 1 Quote Link to comment
banzai510(hainz) Posted September 13 Report Share Posted September 13 (edited) put stock 521 headlamps back in. does blow fuse???? NO. then go to H4 harness with your new lamps if higher wattage youll need a H4 wire harness. it hooks up to the stock outer plug where the lamp is and triggers the new harness I forget if the harness will nedd to be switchable power or ground.the later datsuns were switchable ground Edited September 13 by banzai510(hainz) 1 Quote Link to comment
banzai510(hainz) Posted September 13 Report Share Posted September 13 https://www.amazon.com/Octane-Lighting-Headlight-4000Lm-Headlamp/dp/B09ZKC69L5/ref=asc_df_B09ZKC69L5?tag=bingshoppinga-20&linkCode=df0&hvadid=80814234798897&hvnetw=o&hvqmt=e&hvbmt=be&hvdev=c&hvlocint=&hvlocphy=&hvtargid=pla-4584413755564164&th=1 if this is the lighting it says plug and play and the LED would use less current. but maybe still need a H4 harness Quote Link to comment
