L320 gas and oil gauge
Crusty320
The gas gauge on my 65’ L320 only works till I hit a half tank then it will only read a half tank even if it’s nearly out I’ve replaced the float but that didn’t work
along with the gas Gauge not working the oil temp isn’t either it is permanently stuck on hot and will not move I don’t know where to start on this any help for either issue is appreciated
  • Replies 9
It's different internally from the J13 sender. That's what I have and it reds backwards. I have the original and it will go back in when it comes up on my 'To-Do' list. I believe that Ted H. posted here that the temp gage is adjustable on the back side to accurize it.
