builte Posted August 30, 2023 Report Share Posted August 30, 2023 From now on I'll only be posting here as I am posting too much about my truck all over the place 😂 right now my on question is, is there a Weber carb that will fit my truck it's a 1986 Nissan 720 king cab automatic transmission datzenmike has informed me that it is not efi but is ecc 1 Quote Link to comment
Stoffregen Motorsports Posted August 31, 2023 Report Share Posted August 31, 2023 Nice. Now easier to follow. Â I don't know anything about stock carbs, but that looks suspiciously like a standard Hitachi bolt pattern. Â Anyone? 1 Quote Link to comment
datzenmike Posted August 31, 2023 Report Share Posted August 31, 2023 Take the carburetor off and look at the stud pattern. The Z24 carb is different than the earlier Z22. Instead of rectangular pattern it's trapezoid. Â This is the distance between the secondary studs on a Z24 intake compared to the L20B... which is also the same as the Z22. Â Â Here's a Z24 carburetor on an L20B intake and hoe much was ground away to make it fit. Â 1 Quote Link to comment
builte Posted August 31, 2023 Author Report Share Posted August 31, 2023 4 hours ago, datzenmike said: Take the carburetor off and look at the stud pattern. The Z24 carb is different than the earlier Z22. Instead of rectangular pattern it's trapezoid. Â This is the distance between the secondary studs on a Z24 intake compared to the L20B... which is also the same as the Z22. Â Â Here's a Z24 carburetor on an L20B intake and hoe much was ground away to make it fit. Â I'm gonna do that tomorrow afternoon I'll be stripping down the engine to clean it and gauge in the cylinders Quote Link to comment
builte Posted August 31, 2023 Author Report Share Posted August 31, 2023 I'll post pics Quote Link to comment
EDM620 Posted August 31, 2023 Report Share Posted August 31, 2023 8 hours ago, Stoffregen Motorsports said: that looks suspiciously like a standard Hitachi bolt pattern More than just suspicious, that looks exactly like the stock Hitachi. I expect that right below the carb is a black plastic riser with an electrical connection - that is the carb warmer. You can easily get a carb rebuild kit for the Hitachi 1 1 Quote Link to comment
builte Posted September 1, 2023 Author Report Share Posted September 1, 2023 58 minutes ago, EDM620 said: More than just suspicious, that looks exactly like the stock Hitachi. I expect that right below the carb is a black plastic riser with an electrical connection - that is the carb warmer. You can easily get a carb rebuild kit for the Hitachi The truck Is completely stock ATM except the alternator which I am rebuilding it's original Quote Link to comment
builte Posted September 1, 2023 Author Report Share Posted September 1, 2023 And yes I can get a rebuild kit I will not be getting rid of the old carb for this reason but I would like to do away with most of the vacuum lines because 🤮 they're gross so that why Im interested in a Weber carb I will be posting pics of the tear down tommarow Quote Link to comment
builte Posted September 1, 2023 Author Report Share Posted September 1, 2023 Anybody have a good ball hone they'd recommend for the z24 cylinders? Quote Link to comment
datzenmike Posted September 1, 2023 Report Share Posted September 1, 2023 Cylinder wall finish depends on the rings you plan to use and if the cylinders were machined over size. 1 Quote Link to comment
builte Posted September 1, 2023 Author Report Share Posted September 1, 2023 Original sized rings if possible Quote Link to comment
builte Posted September 1, 2023 Author Report Share Posted September 1, 2023 Well I'm gonna be holding on photos of the teardown cause there isn't a single place we're I live that sale bore mics Quote Link to comment
datzenmike Posted September 1, 2023 Report Share Posted September 1, 2023 Well if just a quick hone 'n ring job then get the softer cast iron rings. Chrome rings need a more perfect round non taper bore. Don't forget most of the wear is at the very tops of the bores. 1 Quote Link to comment
Stoffregen Motorsports Posted September 1, 2023 Report Share Posted September 1, 2023 (edited) 5 hours ago, builte said: Anybody have a good ball hone they'd recommend for the z24 cylinders? Go to Summit Racing and search for ball hone. You can get them for about $25. Â As for what grit to use... Stolen from the web - Â Â EDIT -Â I just realized this quote was referring to honing stones, but I do remember that the product listings show the grit. Edited September 1, 2023 by Stoffregen Motorsports 1 Quote Link to comment
builte Posted September 1, 2023 Author Report Share Posted September 1, 2023 Ok awesome great information from both of you I really appreciate it I'll get the stuff ordered and post more when I can tommarow I'll pulling the engine regardless to post pics of the carb 1 Quote Link to comment
Stoffregen Motorsports Posted September 1, 2023 Report Share Posted September 1, 2023 Oh, also, the right rhythm is needed when honing. I use a one-oun-thou-sand count. One-one on the down stroke, thou-sand on the up stroke. Use WD40 for lube and use low speed on the drill. 1 Quote Link to comment
builte Posted September 1, 2023 Author Report Share Posted September 1, 2023 Ok awesome for how long would you recommend? Quote Link to comment
builte Posted September 1, 2023 Author Report Share Posted September 1, 2023 Also what diameter would the ball hone need to be I'm just trying to do a cleanup and new rings nothing extensive atm. Quote Link to comment
Stoffregen Motorsports Posted September 1, 2023 Report Share Posted September 1, 2023 You can squeeze a "too-big" hone in any cylinder, as long as it's not too too big. I can't advise there. Maybe grab one for the "right size" and see how it feels. Â Ten or twelve strokes on each bore is all that it should take. 1 Quote Link to comment
builte Posted September 1, 2023 Author Report Share Posted September 1, 2023 Ok cool I'll have to measure the cylinders then when I get the head taken off to get an idea of what I want thank you. 1 Quote Link to comment
builte Posted September 1, 2023 Author Report Share Posted September 1, 2023 2 hours ago, datzenmike said: Well if just a quick hone 'n ring job then get the softer cast iron rings. Chrome rings need a more perfect round non taper bore. Don't forget most of the wear is at the very tops of the bores. Do you know if dnr rings are iron? Quote Link to comment
EDM620 Posted September 2, 2023 Report Share Posted September 2, 2023 9 hours ago, datzenmike said: get the softer cast iron rings The softer rings will seat in faster 1 Quote Link to comment
builte Posted September 2, 2023 Author Report Share Posted September 2, 2023 6 hours ago, EDM620 said: The softer rings will seat in faster That's the plan do you know if dnr sales cast iron rings? Quote Link to comment
builte Posted September 2, 2023 Author Report Share Posted September 2, 2023 Dnj* Quote Link to comment
