Crusty320 Posted August 25, 2023 Report Share Posted August 25, 2023 Having trouble removing the brake drum on my L320 it will spin but will not move when trying to take it off I have tried soaking in penetrating oil and a pry bar but it won’t budge. Any help is welcome. -crusty Quote Link to comment
Crashtd420 Posted August 25, 2023 Report Share Posted August 25, 2023 10 hours ago, Crusty320 said: Having trouble removing the brake drum on my L320 it will spin but will not move when trying to take it off I have tried soaking in penetrating oil and a pry bar but it won’t budge. Any help is welcome. -crusty Its probably rusted to the hub.... Are you trying to save the drum and reuse it? Some heat might help.... On my 521 I actually had to cut the drum off.... Quote Link to comment
Crashtd420 Posted August 25, 2023 Report Share Posted August 25, 2023 Actually does it move in and out at all when trying to remove? The other thing could be a ridge on the drum trapping the pads behind it... Did you back off the adjusters to loosen the pads? Quote Link to comment
bilzbobaggins Posted August 25, 2023 Report Share Posted August 25, 2023 320 drums have the jacking points on the face? If there are two holes in the face of the drum, find a bolt (I dont know the size) and run them down to push the drum off. But if the shoes are not retracted it will tear stuffs up. Quote Link to comment
Crusty320 Posted August 25, 2023 Author Report Share Posted August 25, 2023 3 hours ago, Crashtd420 said: Actually does it move in and out at all when trying to remove? The other thing could be a ridge on the drum trapping the pads behind it... Did you back off the adjusters to loosen the pads? it doesn’t move at all and I haven’t loosed the pads I am trying to reuse the drum I just need to get in there to replace the cylinder Quote Link to comment
Crashtd420 Posted August 25, 2023 Report Share Posted August 25, 2023 5 minutes ago, Crusty320 said: it doesn’t move at all and I haven’t loosed the pads I am trying to reuse the drum I just need to get in there to replace the cylinder Well first thinks first is loosen the pads.... back the adjusters off as far as you can and see what happens... Sometimes some heavy strikes with a hammer on the face, kind of to the outside edge, can loosen things .... Maybe some heat to start, then hit with penetrating oil in the center... sometimes the heat helps draw it into places.... I have never had good luck using the bolts to get it off.... I wouldn't recommend if trying to reuse the drum. Quote Link to comment
Stoffregen Motorsports Posted August 25, 2023 Report Share Posted August 25, 2023 Yes, I believe there are two threaded holes in the drum. Put some bolts in there to help free it from the hub/axle flange. If it's really stuck, you will need to heat it good. Just around the inner bore, where it's seated against the flange. Heat it up and give it a try. If it doesn't budge, heat it again and squirt it down with some WD40 and walk away. The lube will get into the mating surfaces as it cools. And yes, don't forget to back off the shoe adjusters. This will help remove the drum once it is free from the flange. 1 Quote Link to comment
wayno Posted August 25, 2023 Report Share Posted August 25, 2023 OK, I believe there are 2 Phillips head screws holding the drum on the end of the axle, look on the face of the drum between the lugs, they have to be removed to get the drums off. 1 Quote Link to comment
Crusty320 Posted August 26, 2023 Author Report Share Posted August 26, 2023 8 hours ago, Crashtd420 said: Well first thinks first is loosen the pads.... back the adjusters off as far as you can and see what happens... Sometimes some heavy strikes with a hammer on the face, kind of to the outside edge, can loosen things .... Maybe some heat to start, then hit with penetrating oil in the center... sometimes the heat helps draw it into places.... I have never had good luck using the bolts to get it off.... I wouldn't recommend if trying to reuse the drum. So how would one find where to loosen pads Quote Link to comment
Crashtd420 Posted August 26, 2023 Report Share Posted August 26, 2023 12 hours ago, Crusty320 said: So how would one find where to loosen pads There should be an access hole on the backing plate..... it's a star wheel adjuster inside..... Quote Link to comment
Crashtd420 Posted August 26, 2023 Report Share Posted August 26, 2023 (edited) This is for a 520/521 but it's the same setup.. Star wheel is at the bottom... Edited August 26, 2023 by Crashtd420 Quote Link to comment
