Brayden Posted August 7, 2023 Report Share Posted August 7, 2023 Heard a few complaints about the fan whine on 720s, and mine also has a bit more whine than I like. Wondering what kind of solutions people have done to quiet it up. Best idea I've got so far is putting electric fans on it and ditching the fan clutch. (Brand new water pump and fan clutch so I know its not that) Quote Link to comment
weldingrod Posted August 7, 2023 Report Share Posted August 7, 2023 Actually, I changed a fan/clutch/pump recently and it was also whining. Turns out the clutch hub was faulty from new and didn't work correctly, the fan started spinning as soon as the truck started. I have it installed, keeps the temp normal so I'm just going to live with it. Quote Link to comment
datzenmike Posted August 7, 2023 Report Share Posted August 7, 2023 You should be able to spin the fan with your finger but there is stiff resistance. The fan cannot be made to spin freely by itself without a push. There is a silicone oil inside that hydraulically couples the fan from the spinning water pump shaft. As the speed increases at some point it can't pull more air through the radiator and it maxes out and won't spin any faster no matter how fast the pump turns. This is sufficient for cooling and saves energy at higher speeds where vehicle motion pushes air through the radiator. If the bearing seizes the fan will turn one to one with the pump and make a roaring sound. If the oil leaks out it will slip excessively and the engine can over heat. Fan will spin easily by hand. Whine is usually the alternator or the fan belt. Quote Link to comment
NC85ST Posted August 7, 2023 Report Share Posted August 7, 2023 Or it could be one of your idler pulleys. 1 Quote Link to comment
Thomas Perkins Posted August 8, 2023 Report Share Posted August 8, 2023 When you replaced your water pump,was both of your dowels in place.One of mine came out,causing the propeller to scrub on the inside.I bought some new ones from Nissan. 1 Quote Link to comment
datzenmike Posted August 8, 2023 Report Share Posted August 8, 2023 I've shortened and ground down a suitable size nail for the timing cover that has the same tiny dowels. 1 Quote Link to comment
Brayden Posted August 8, 2023 Author Report Share Posted August 8, 2023 Im pretty sure everything went on how it came off, and to respond to an earlier reply, I also replaced the alternator and all the belts while I was in there. I dont hear any scrubbing from the pump, engine seems to run real smooth. The only thing on the front end service I did not replace were the pulleys Quote Link to comment
Thomas Perkins Posted August 8, 2023 Report Share Posted August 8, 2023 1 hour ago, datzenmike said: I've shortened and ground down a suitable size nail for the timing cover that has the same tiny dowels. Cool Quote Link to comment
Thomas Perkins Posted August 8, 2023 Report Share Posted August 8, 2023 1 hour ago, Brayden said: Im pretty sure everything went on how it came off, and to respond to an earlier reply, I also replaced the alternator and all the belts while I was in there. I dont hear any scrubbing from the pump, engine seems to run real smooth. The only thing on the front end service I did not replace were the pulleys Nissan still has them.I replaced my power steering one not long ago. Quote Link to comment
Thomas Perkins Posted August 8, 2023 Report Share Posted August 8, 2023 Your fan could be scrubbing on the lower fan shroud.You can see the end of the fan blade scuffed up on mine.I have a tie wrap holding my lower stroud tight.There is nothing down there to hold it in place.Mostly everyone has after market radiators and the shroud don't fit the same down there.Check your fan blade ends.Their is a hole at the bottom of the shroud where you can connect 2 tie wraps and connect to frame down there. Quote Link to comment
NC85ST Posted August 8, 2023 Report Share Posted August 8, 2023 If it is idler pulley noise, you can just replace the bearings and not the entire pulley. Quote Link to comment
