jagman Posted July 31, 2023 Report Share Posted July 31, 2023 My truck has been running like a champ. Several days ago it would click but not turn the starter occasionally. I have checked the wiring connections- all seems to be tight. Put a jumper on it and it fires right up. Battery tests to 12.54 volts so the battery seems to be fully charged. What am I missing here? Quote Link to comment
DwayneOxford Posted August 1, 2023 Report Share Posted August 1, 2023 Was starter solenoid on mine. Only a few dollars more to replace starter and solenoid assembly. Quote Link to comment
flyerdan Posted August 2, 2023 Report Share Posted August 2, 2023 Most likely solenoid. I had that on the forklift a few years ago, took the solenoid apart and cleaned all the carbon dust out, carefully tapped the two square head copper bolts out of the end cap, burnished them and the plunger on a wire wheel and reinstalled the bolts with the uneroded part of the head inwards. Works like a new starter. Quote Link to comment
datzenmike Posted August 2, 2023 Report Share Posted August 2, 2023 Jumper 12v directly from the battery to the small terminal that has the Black/Red wire on it that is the START signal from the ignition key. If it starts perfectly every time it is NOT the solenoid but a weak voltage signal from the ignition switch.. My 710 was hit or miss and the start signal was 7-8 volts. There is a fix for this weak signal Quote Link to comment
jagman Posted August 2, 2023 Author Report Share Posted August 2, 2023 OK Mike, What is the fix? Quote Link to comment
datzenmike Posted August 2, 2023 Report Share Posted August 2, 2023 Well test this out first. Is it a weak start signal from the ignition? Quote Link to comment
jagman Posted August 3, 2023 Author Report Share Posted August 3, 2023 I put a jumper direct to the battery from the solenoid and got the same results. It will turn the starter about 50% of the time strongly enough to start the engine. So I would guess that the voltage from the switch is OK. I will pull the starter/solenoid. Quote Link to comment
datzenmike Posted August 3, 2023 Report Share Posted August 3, 2023 Alright that eliminates the ignition switch as the fault. I guess it looks like the solenoid is worn out. If you have a spare starter then this can be done with the starter in the vehicle and if not buy a new starter. Always wise to never throw old parts away. There is usually something on it of use. 1 Quote Link to comment
DwayneOxford Posted August 3, 2023 Report Share Posted August 3, 2023 1 hour ago, datzenmike said: Alright that eliminates the ignition switch as the fault. I guess it looks like the solenoid is worn out. If you have a spare starter then this can be done with the starter in the vehicle and if not buy a new starter. Always wise to never throw old parts away. There is usually something on it of use. What most folks call junk, I call resources. Keep on truckin. Quote Link to comment
datzenmike Posted August 3, 2023 Report Share Posted August 3, 2023 I just go out and mow my lawn to access my parts. 1 Quote Link to comment
jagman Posted August 4, 2023 Author Report Share Posted August 4, 2023 Gee Mike, I keep some parts in a shed others are still on the junk trucks. I have substituted a starter with solenoid from one of the junkers. I noticed that the solenoid was at a different angle and the body of the starter larger than the original. It fit and the solenoid easier to reach. I will test the setup today in the truck the bench test was OK. Quote Link to comment
Thomas Perkins Posted August 4, 2023 Report Share Posted August 4, 2023 23 hours ago, datzenmike said: I just go out and mow my lawn to access my parts. What kind of lawn mower you got Mike. Tell the truth. Quote Link to comment
datzenmike Posted August 4, 2023 Report Share Posted August 4, 2023 Electric, what else? 1 Quote Link to comment
datzenmike Posted August 5, 2023 Report Share Posted August 5, 2023 ... well it isn't burn barrel powered. Quote Link to comment
jagman Posted August 5, 2023 Author Report Share Posted August 5, 2023 Truck is fixed. Mike I haven't seen an electric brush cutter - maybe only in canada? Quote Link to comment
datzenmike Posted August 5, 2023 Report Share Posted August 5, 2023 Lawn mower. Quote Link to comment
