six2ohyea Posted July 9, 2023 Report Share Posted July 9, 2023 Got some new wheels and tires on the truck. But now my truck is sitting crooked. What could it be? Have 3” blocks in the rear. front driver side rear driver side Rear passenger side Quote Link to comment
six2ohyea Posted July 9, 2023 Author Report Share Posted July 9, 2023 front passenger side Quote Link to comment
Crashtd420 Posted July 9, 2023 Report Share Posted July 9, 2023 as for why who knows.. Maybe jack it up and down again see if something got hung up or stuck... should be a simple enough correction.... just adjust the torsion bar on the driver side front.... 1 Quote Link to comment
datzenmike Posted July 10, 2023 Report Share Posted July 10, 2023 Check the air pressure in all. Tires and rims won't normally do this. The act of changing them might, as previously stated. When jacking did you use the frame and let the wheel droop or under the lower control arm? Not that it matters which but maybe one of the shocks was affected by full extension? Quote Link to comment
Stoffregen Motorsports Posted July 13, 2023 Report Share Posted July 13, 2023 Roll it back and forth and check again. Quote Link to comment
EDM620 Posted August 3, 2023 Report Share Posted August 3, 2023 Just thinking out loud here. Make sure you have it parked on even level ground and compare measurements to the ground to frame as well as ground to the body. It is possible that the body mount rubbers are collapsed, afterall they are just a few years old. And have you done a suspension/shock bounce? Quote Link to comment
