None_zero Posted March 26, 2023 Author Report Share Posted March 26, 2023 Not even visible unless I max it all the way counter clockwise Quote Link to comment
banzai510(hainz) Posted March 26, 2023 Report Share Posted March 26, 2023 let it warm up then try it again to me it looks so close but L motors like more advancde like 12 even dough soem say 7-15degs just depending. unless you took the dist shaft out and reinstalled it off a tooth where it will be more exact. Look at mikes fofot on the L motor if you have a screw driver the line would be right side of the top hole and left on the bottom I call it like 11.25 to me or more 11.30 where almost up and down but not exactly. but you have thwe photo. Now if you never fucked with installing the dist /oil pump shaft and was fine before then you did soemthing to the upper part. I didnt read your whole thread only catching part now. is there another bolt under the dist plate with maight give more adjust or its a one hole fixed? Quote Link to comment
datzenmike Posted March 26, 2023 Report Share Posted March 26, 2023 Z20/Z22 is 5 and Z24 is 3 Well where ever the distributor ends up at the end of the day all you really need is +3 BTDC. Doesn't matter how you get it. Quote Link to comment
banzai510(hainz) Posted March 26, 2023 Report Share Posted March 26, 2023 if this is dual plug can this be swapped Mike?where he put the later FIRE to fire sooner? Quote Link to comment
None_zero Posted March 26, 2023 Author Report Share Posted March 26, 2023 I reversed the distributor cap just now and it got me closer now if I retard all the way I can get it to 20° advanced Quote Link to comment
None_zero Posted March 26, 2023 Author Report Share Posted March 26, 2023 But I clipped the timing light on a wire from each cylinder and seems like 2and 4 are irregular and 3 is no fire bit it will sit there and idle Quote Link to comment
None_zero Posted March 26, 2023 Author Report Share Posted March 26, 2023 (edited) When the distributor cap is on correctly is the Intake wire above or below the exhaust wire I'll be honest I thought it only went on one way and so didn't pay attention to how it was Edited March 26, 2023 by None_zero Quote Link to comment
None_zero Posted March 26, 2023 Author Report Share Posted March 26, 2023 24 minutes ago, banzai510(hainz) said: let it warm up then try it again to me it looks so close but L motors like more advancde like 12 even dough soem say 7-15degs just depending. unless you took the dist shaft out and reinstalled it off a tooth where it will be more exact. Look at mikes fofot on the L motor if you have a screw driver the line would be right side of the top hole and left on the bottom I call it like 11.25 to me or more 11.30 where almost up and down but not exactly. but you have thwe photo. Now if you never fucked with installing the dist /oil pump shaft and was fine before then you did soemthing to the upper part. I didnt read your whole thread only catching part now. is there another bolt under the dist plate with maight give more adjust or its a one hole are you talking about the spindle into the oil pump? Quote Link to comment
banzai510(hainz) Posted March 26, 2023 Report Share Posted March 26, 2023 you got a manual? Mike will know Quote Link to comment
None_zero Posted March 26, 2023 Author Report Share Posted March 26, 2023 Yes it's a manual Quote Link to comment
None_zero Posted March 26, 2023 Author Report Share Posted March 26, 2023 It you're referring to the thing in the picture set to 11:25 yes that is what I was already attempting to correct but if your referring to something higher up in the distributor I want to hear about it Quote Link to comment
None_zero Posted March 26, 2023 Author Report Share Posted March 26, 2023 20 minutes ago, None_zero said: When the distributor cap is on correctly is the Intake wire above or below the exhaust wire I'll be honest I thought it only went on one way and so didn't pay attention to how it was @datzenmikeyou said it wouldn't start if I reversed the distributor cap but it not only starts it idles both ways what does that mean Quote Link to comment
None_zero Posted March 27, 2023 Author Report Share Posted March 27, 2023 I started pulling the plugs to check their condition cylinder three exhaust side has liquid oil on it I think Quote Link to comment
None_zero Posted March 27, 2023 Author Report Share Posted March 27, 2023 I guess unturned fuel is more likely Quote Link to comment
None_zero Posted March 27, 2023 Author Report Share Posted March 27, 2023 (edited) Well yes it turns out I did have the cap reversed which I know because I just realized I'd made a handy diagram of it under the hood last year rotate picture counter clockwise 90° for correct orientation Edited March 27, 2023 by None_zero Quote Link to comment
None_zero Posted March 27, 2023 Author Report Share Posted March 27, 2023 But the problem is that even with it swapped back it still doesn't seem to be working Quote Link to comment
None_zero Posted March 27, 2023 Author Report Share Posted March 27, 2023 What's that mark on the housing there for? Quote Link to comment
None_zero Posted March 27, 2023 Author Report Share Posted March 27, 2023 (edited) Ok so I had the idea to take the screw put of the fixing plate and see if I can rotate it far enough to get in the right spot just to see if it would work if I'd hit the right tooth. I think that has to be the problem. I missed byba tooth the other way and its too far to hit the needed range. Anyways but when I'm unscrewing the screw from the fixing plate it's throwing little orange sparks??? Why would it do that ? Strangest looking sparks I've ever seen Edited March 27, 2023 by None_zero Quote Link to comment
None_zero Posted March 27, 2023 Author Report Share Posted March 27, 2023 I need to be driving this thing by morning so any help Is appreciated Quote Link to comment
None_zero Posted March 27, 2023 Author Report Share Posted March 27, 2023 1 hour ago, banzai510(hainz) said: you got a manual? Mike will know Oh you mean a manual like a book lol yeah I got the fsm but it doesn't have that much information about this, it just says mark everything install as was but that was the problem originally I pulled the oil pump without realizing you need to mark things and that it had to go back in a very specific way Quote Link to comment
None_zero Posted March 27, 2023 Author Report Share Posted March 27, 2023 21 minutes ago, None_zero said: Ok so I had the idea to take the screw put of the fixing plate and see if I can rotate it far enough to get in the right spot just to see if it would work if I'd hit the right tooth. I think that has to be the problem. I missed byba tooth the other way and its too far to hit the needed range. Anyways but when I'm unscrewing the screw from the fixing plate it's throwing little orange sparks??? Why would it do that ? Strangest looking sparks I've ever seen Just trying to get this to the bottom Mike tends to over look all but the last one lol Quote Link to comment
datzenmike Posted March 27, 2023 Report Share Posted March 27, 2023 #1 Intake should be about 9:00 rotor pointing directly forward ti the radiator. #1 Exhaust about 4:30. Stand beside front fender. The sparks are because the ignition is on. Coil grounds through the distributor body. Quote Link to comment
None_zero Posted March 27, 2023 Author Report Share Posted March 27, 2023 (edited) Turn picture so that blue arrow points away from you. Red arrow intake one, blue arrow exhaust 4, yellow arrow intake 2. That means it was backwards before and it's correct now but with distributor maxed out counter clockwise it's 15 degrees advanced is it going to have screwed anything up to have it idling with the cap installed backwards? Or am I just a tooth too far forward now Edited March 27, 2023 by None_zero Quote Link to comment
None_zero Posted March 27, 2023 Author Report Share Posted March 27, 2023 (edited) Welp, I redid the spindle and hit the right tooth finally but it's still running terribly it says it's at 5° but I can't be sure of the rpms to set it and when I tried to test drive it it felt like a caterpillar in the engine it feels like everything is out of wack.. I don't know what to do with it. Maybe i should be more specific about the caterpillar... it feels like a wave of vibration rolling though it as it runs in like vruuuuh vruuuh vruuuuuuh don't know how else to describe it. Edited March 27, 2023 by None_zero Quote Link to comment
None_zero Posted March 27, 2023 Author Report Share Posted March 27, 2023 The upside? I'm back in the middle of the adjustment range. The downside there's no way I can drive it as is. Quote Link to comment
