510 steering box?
Lonewolf1990
  • Replies 4
1 hour ago, Lonewolf1990 said:
Does a 510 steering box work on a 620?
Absolutely not. The 620 is a one piece steering column with integral steering box. Closest thing is another 620 or 521 column and box.
I have put a 720 steering box on a 620. The 720 column is connected to the box via a rag joint and a U joint and is detachable. However the 720 sector shaft is on the outside of the 620's left frame rail where the 620 is on the inside of the frame. This won't match the 620's idler arm on the inside of the right side frame. I guess a 720 idler could be used but I doubt the cross rod has enough adjustment to accommodate both new positions. Perhaps using all the 720 steering components might work.
I did something different as this was a SAS.
