Socalman Posted January 24 Report Share Posted January 24 I think it seems to be 6” but I don’t have the right tools to get an accurate measurement short of taking tire off and measuring. I can fit the stock 14” wheel with the front disk brake conversion but turning the wheel around gets me close the the offset I’m going to need short of knowing rim width. Thanks! Quote Link to comment
mainer311 Posted January 24 Report Share Posted January 24 (edited) I have a wheel in my garage without a tire that I can measure later. It’s definitely more narrow than 6”. I don’t know how wide your flares are, but an 8” rim with a -19 offset would probably fit almost exactly how you want them. Edited January 24 by mainer311 Quote Link to comment
datzenmike Posted January 24 Report Share Posted January 24 Should be same as the early 620. It says 4" and later 4.5".... but that seems kind of narrow to me. 1 Quote Link to comment
Socalman Posted January 24 Author Report Share Posted January 24 42 minutes ago, mainer311 said: I have a wheel in my garage without a tire that I can measure later. It’s definitely more narrow than 6”. I don’t know how wide your flares are, but an 8” rim with a -19 offset would probably fit almost exactly how you want them. Thing is that picture there is with a 2" spacer, which I would need to run to clear calipers with anything less that a 16" wheel. I want to run a 15" wheel, so I assume the 8" with -19 is based on a stock brake setup? I appreciate you checking on that width later. Quote Link to comment
mainer311 Posted January 24 Report Share Posted January 24 (edited) I’m running 15x8’s, -19, and I clear D21 4wd brakes. Mike is right, they’re 4” Edited January 24 by mainer311 Quote Link to comment
Socalman Posted January 25 Author Report Share Posted January 25 1 hour ago, mainer311 said: I’m running 15x8’s, -19, and I clear D21 4wd brakes. Mike is right, they’re 4” Wow, ok. Thank you Quote Link to comment
Socalman Posted January 25 Author Report Share Posted January 25 So if I’m converting this correctly since I’m not familiar with offset, -19 is equal to 3.75” backspace? Backspace I’ve dealt with in racing. 😂 Quote Link to comment
Socalman Posted January 25 Author Report Share Posted January 25 1 hour ago, mainer311 said: I’m running 15x8’s, -19, and I clear D21 4wd brakes. Mike is right, they’re 4” Do your wheels stick out any with that offset and width? Quote Link to comment
mainer311 Posted January 25 Report Share Posted January 25 21 minutes ago, Socalman said: Do your wheels stick out any with that offset and width? Yes. Probably a bit too much, but not terrible. I also don’t have flares. 1 Quote Link to comment
mklotz70 Posted January 25 Report Share Posted January 25 (edited) ... Edited January 26 by mklotz70 Quote Link to comment
datzenmike Posted January 25 Report Share Posted January 25 20 hours ago, datzenmike said: Should be same as the early 620. It says 4" and later 4.5".... but that seems kind of narrow to me. This is because I didn't run the stock rims for long and ran 6 bolt Ford or Chev rims that were 6" or 7" wide. They looked fine with 33s on them. Quote Link to comment
Socalman Posted January 25 Author Report Share Posted January 25 2 hours ago, mklotz70 said: If you're looking to run stock rims, my brake kit is the only one. I have two left....more info on my site.... bluehandfab.com More info on the stock rims..... I don't need another brake kit, I have one installed already, that I want to run with 15" wheels. I just want to get offset right and find out how to check if they will clear the calipers I have and look good with the bodykit I have with fender flares, I now know the 14" do not clear calipers. I am however interested in the MC rod and adj tension rod, site says it is not setup for payments. Quote Link to comment
datzenmike Posted January 25 Report Share Posted January 25 Where are they not clearing? Grinding the caliper is an option if only small amount. 2" spacer??? insane amount. Not enough homework done before buying brake kit. Too late now but make the brakes fit the truck, not the truck fit the brakes. Tires should be inside fender or flair. Eventually you'll hit something unforeseen and the body will come down on that flare and wreck it. Not to mention dirt flung up by the extended tire. Quote Link to comment
Socalman Posted January 25 Author Report Share Posted January 25 1 hour ago, datzenmike said: Where are they not clearing? Grinding the caliper is an option if only small amount. 2" spacer??? insane amount. Not enough homework done before buying brake kit. Too late now but make the brakes fit the truck, not the truck fit the brakes. Tires should be inside fender or flair. Eventually you'll hit something unforeseen and the body will come down on that flare and wreck it. Not to mention dirt flung up by the extended tire. The brakes fit the truck! lol. I have the brakes that I wanted on the truck, Now I'm doing my homework on the best wheel fit with the flares and brake kit. That picture there is just the stock wheel flipped around for measurement purposes, therefore the reason for asking its width....the brake kit requirements called for......16 inch wheels Minimum. 16 inch steel sunraisers were tested by a customer and did not fit without wheel spacer. Diameter of 16 inch is fine. The shape of the face of the wheel will be the deciding factor if it will rub the caliper or not. Any 16 will work with a 1 inch wheel spacer. Or get a 17 inch wheel and have no spacer. 2006 Nissan Titan stock oem wheels will fit without spacer. BUT, HERES THE BIG BUT, THEY HAVE A PICTURE OF A CUSTOMER WHOM INSTALLED THIS KIT AND USED A 15" WHEEL, they couldn't give me any info on it when I asked if they knew what spacer or backspacing was used, only that it was a Rota wheel.... 1 Quote Link to comment
datzenmike Posted January 26 Report Share Posted January 26 The brakes fit the truck but don't fit the rims, thus they don't really fit the truck. These couldn't have been for a 521. Well again, where is it rubbing on the caliper? If on top you may be able to grind some metal away for clearance. If on the face a rim with more negative off set would space it away from the caliper. Quote Link to comment
Socalman Posted January 26 Author Report Share Posted January 26 Well, I’ll know more once I get my hands on some 15s if it’s minor enough if any to take some material off….I’ll keep you posted. Quote Link to comment
mainer311 Posted January 26 Report Share Posted January 26 (edited) Those Rotas (RB’s) are 5 lug, so either they went the Tanker route and changed hubs, or they (more likely) used 6 to 5 lug adapters, thus spacing the 15” wheels away from the calipers. Edited January 26 by mainer311 Quote Link to comment
Socalman Posted January 26 Author Report Share Posted January 26 13 hours ago, mainer311 said: Those Rotas (RB’s) are 5 lug, so either they went the Tanker route and changed hubs, or they (more likely) used 6 to 5 lug adapters, thus spacing the 15” wheels away from the calipers. correct, either way I know its at least 1" spacer, that's way I have 2" spacers that I can always have machined to less if needed. offset is what I'm still working on to get close to the look I need/want. I'm leaning towards 4" BS with 8" wide rim or 3" BS with 7" Quote Link to comment
mainer311 Posted January 26 Report Share Posted January 26 (edited) I've been looking at wheels from Japan lately, and there are usually a couple good offsets. (Better than what I have now.) They're 15x8 +0, and 15x7 -13. The area to watch out for on these trucks is the inset on the wheel, because too much inset will allow the tires to contact the tension rods in the front. Edited January 26 by mainer311 2 Quote Link to comment
Stoffregen Motorsports Posted January 27 Report Share Posted January 27 23 hours ago, Socalman said: correct, either way I know its at least 1" spacer, that's way I have 2" spacers that I can always have machined to less if needed. offset is what I'm still working on to get close to the look I need/want. I'm leaning towards 4" BS with 8" wide rim or 3" BS with 7" Simple spacers can be machined, but spacers with studs in them can not be machined. Machining them would weaken them. 1 Quote Link to comment
