DTZ Posted August 30, 2022 Report Share Posted August 30, 2022 My backing plates are making noises while going over bumps and pot holes. I can't seem to find new ones, maybe I have them in wrong?I tried rotating them up and down in position. Is there retro-fit caliper for 13" wheels? Thanks! Quote Link to comment
datzenmike Posted August 30, 2022 Report Share Posted August 30, 2022 What's this for??? 13" so... 510? Drum brakes have backing plates, maybe you mean splash guards? They can get pretty rusty and fall apart. Might be better to just take them off and run without. The 610 through '74 and the 710 through '75 used the same caliper but if looking through auto supply stores they'll know this. After the '74 610 and '75 710 the calipers were changed to dual pistons and larger pads. They should retro fit the earlier 610 and thus the 510. Quote Link to comment
banzai510(hainz) Posted August 30, 2022 Report Share Posted August 30, 2022 isnt there anti sqeek grease or that red stuff for pads. better description would help! rea brakes. I used a grease on shoes wear the wear spot is Quote Link to comment
DTZ Posted August 30, 2022 Author Report Share Posted August 30, 2022 https://mail.yahoo.com/d/folders/1/messages/AAqoHQ8rkCsjYw4bAQ7kgCDgCzU Quote Link to comment
DTZ Posted August 30, 2022 Author Report Share Posted August 30, 2022 It's a 1970 510. Front, stock calipers. A better description is the "pad clips"? The part that holds the pads in place. Quote Link to comment
banzai510(hainz) Posted August 30, 2022 Report Share Posted August 30, 2022 usually those never squeek those pad clips. its the back of the pads. I spayed the red anti squeal stuff on there. Just dont drop it in the dirt its fucking sticky and picks up everthing. Youll be yelling FUCK!!!! Quote Link to comment
datzenmike Posted August 30, 2022 Report Share Posted August 30, 2022 Yahoo???? they want me to join so I can see your pictures. Screw that. These...? they're called "anti rattle clips" Quote Link to comment
DTZ Posted August 31, 2022 Author Report Share Posted August 31, 2022 Yes those! they are rattling with the OEM pads. Quote Link to comment
DTZ Posted August 31, 2022 Author Report Share Posted August 31, 2022 I couldn't find the "upload" option.. Quote Link to comment
datzenmike Posted August 31, 2022 Report Share Posted August 31, 2022 I would remove them and go for a drive to be sure that's the rattle. Could be a rusted out splash guard. Try bending them so they clip on tighter. Quote Link to comment
DTZ Posted August 31, 2022 Author Report Share Posted August 31, 2022 Okay, I'll take them out, thanks! Jim Quote Link to comment
datzenmike Posted August 31, 2022 Report Share Posted August 31, 2022 Just to verify they are the cause of the sound. I don't think they are. Definition of irony: my anti rattle clips are the cause of the rattle. Quote Link to comment
Stoffregen Motorsports Posted August 31, 2022 Report Share Posted August 31, 2022 The clips may rattle, but they keep the pads from rattling against the rotor. I used to ditch all that crap, but in the wisdom of my years, I've learned how to keep those types of things on a vehicle. I would try bending them, as suggested, and use some caliper grease on them only where they contact the pads. Then they shouldn't squeal or rattle. Quote Link to comment
yenpit Posted September 6, 2022 Report Share Posted September 6, 2022 I have quite a few stock 510 calipers & misc caliper parts if you need anything. I will also have stock 510 front "splash shields" (behind the rotors). I might even have NOS hardware in the parts load that I got a few months ago, but would have to dig...........PM me if you need anything! Quote Link to comment
DTZ Posted September 9, 2022 Author Report Share Posted September 9, 2022 So I bent the anti rattle clips and put the anti- rattle goop on them. Much better, no noise! I discovered another noise that was in the background that became louder. It was the metal vacuum tube to the automatic transmission, it was loose, rattling on the bell housing! Thanks for the support!!! Quote Link to comment
