Joecar Posted August 25, 2022 Report Share Posted August 25, 2022 So i noticed this while driving and was confused on what this could be but whenever i go to turn my blinker on, the bulbs stay on Quote Link to comment
Joecar Posted August 25, 2022 Author Report Share Posted August 25, 2022 A Just now, Joecar said: So i noticed this while driving and was confused on what this could be but whenever i go to turn my blinker on, the bulbs stay on Also the hazard switch is stuck so i cant turn it on either Quote Link to comment
datzenmike Posted August 25, 2022 Report Share Posted August 25, 2022 32 minutes ago, Joecar said: So i noticed this while driving and was confused on what this could be but whenever i go to turn my blinker on, the bulbs stay on Just on one side? If so check for a bulb that is burnt out on that side. If both sides light then swap turn signal with the 4 way emergency flasher. If that gets them working then the flasher unit is bad. 31 minutes ago, Joecar said: A Also the hazard switch is stuck so i cant turn it on either Split the plastic clam shell around the steering colum to get at the 4 way switch. You may be able to take it apart and loosen it. Other than that you will have to replace it. Quote Link to comment
Joecar Posted August 25, 2022 Author Report Share Posted August 25, 2022 1 hour ago, datzenmike said: Just on one side? If so check for a bulb that is burnt out on that side. If both sides light then swap turn signal with the 4 way emergency flasher. If that gets them working then the flasher unit is bad. Split the plastic clam shell around the steering colum to get at the 4 way switch. You may be able to take it apart and loosen it. Other than that you will have to replace it. Both sides are doing the same and the switch is stuck so that means i need to replace the entire assembly? Quote Link to comment
datzenmike Posted August 25, 2022 Report Share Posted August 25, 2022 Power to the turn signals has to pass through the 4 way switch. When the 4 way is on the turn signals are disconnected then connected back up when the 4 way is turned off. As the 4 way is 'stuck' possibly the turn signal problem will resolve itself if the 4 way is fixed. Finding another 4 way switch may be harder than simply taking apart and cleaning it. The 720 4 way switch has a problem of sliding too far when placed in the off position. It goes past the turn signal contacts and disconnects them causing the turns to be inoperative. Usually moving the switch slightly towards the 4 way position connects them back up. Quote Link to comment
Stoffregen Motorsports Posted August 25, 2022 Report Share Posted August 25, 2022 Most times you don't even need to take it apart to clean it. I squirt them down with WD40 and switch them back and forth until the motion is free again, then I blow it off with air then wipe it down. If you can fit a small wire brush in there, or even an old toothbrush, this will help clean the contacts and get the gunk out of the mechanism. Same goes for the hazard switch. Squirt it with WD40 then try working it back and forth. Be careful you don't break the plastic knob. If either switch is really dirty, I will spray it with Purple Power first then hose it off, and then do the WD40. 1 Quote Link to comment
Joecar Posted August 31, 2022 Author Report Share Posted August 31, 2022 On 8/25/2022 at 6:38 AM, datzenmike said: Power to the turn signals has to pass through the 4 way switch. When the 4 way is on the turn signals are disconnected then connected back up when the 4 way is turned off. As the 4 way is 'stuck' possibly the turn signal problem will resolve itself if the 4 way is fixed. Finding another 4 way switch may be harder than simply taking apart and cleaning it. The 720 4 way switch has a problem of sliding too far when placed in the off position. It goes past the turn signal contacts and disconnects them causing the turns to be inoperative. Usually moving the switch slightly towards the 4 way position connects them back up. I cleaned the 4 ways and they work bow but my blinkers still are just not working the green arrow is just staying on Quote Link to comment
datzenmike Posted August 31, 2022 Report Share Posted August 31, 2022 Just the right side????? Take a look at the front and rear right signal lamps. The one that is not lit is burned out. Quote Link to comment
Joecar Posted August 31, 2022 Author Report Share Posted August 31, 2022 3 hours ago, datzenmike said: Just the right side????? Take a look at the front and rear right signal lamps. The one that is not lit is burned out. Its both sides and whenever i have them on all the lights work. The only thing i have done really is put some LED brake bulbs that were laying around that i had so could that be the problem? Quote Link to comment
Crashtd420 Posted August 31, 2022 Report Share Posted August 31, 2022 7 hours ago, Joecar said: Its both sides and whenever i have them on all the lights work. The only thing i have done really is put some LED brake bulbs that were laying around that i had so could that be the problem? Try switching back to regular bulbs and see if the problem goes away.... They make adjustable flasher relays so you can adjust how fast or slow they flash.... I had to do that when I used leds in my taillights... https://www.ebay.com/itm/175356504551?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=hxzu6dwjs_m&sssrc=2349624&ssuid=2B08jY5FRkS&var=&widget_ver=artemis&media=COPY Quote Link to comment
datzenmike Posted August 31, 2022 Report Share Posted August 31, 2022 The Datsun flashers are load dependent. They are designed to work with two incandescent filament bulbs per side. I added a 7 or 8 ohm 20 watt* resister to the left and the right side flasher circuit to simulate each 20 watt bulb.... and away I went. * 1.6 amps through 7 ohms resistance is going to generate some heat so use 20 watt resistance to be safe. You can go higher wattage if you want but 20 minimum. 20 watt bulb 20 watts is 1.66 amps current flow 12 volts/1.66 amps is 7.22 ohms resistance 1 Quote Link to comment
Joecar Posted September 1, 2022 Author Report Share Posted September 1, 2022 On 8/31/2022 at 5:32 AM, Crashtd420 said: Try switching back to regular bulbs and see if the problem goes away.... They make adjustable flasher relays so you can adjust how fast or slow they flash.... I had to do that when I used leds in my taillights... https://www.ebay.com/itm/175356504551?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=hxzu6dwjs_m&sssrc=2349624&ssuid=2B08jY5FRkS&var=&widget_ver=artemis&media=COPY Swithed back to regular bulbs and still not working. Its weird cause it worked before and then it stopped Quote Link to comment
Joecar Posted September 1, 2022 Author Report Share Posted September 1, 2022 On 8/31/2022 at 6:20 AM, datzenmike said: The Datsun flashers are load dependent. They are designed to work with two incandescent filament bulbs per side. I added a 7 or 8 ohm 20 watt* resister to the left and the right side flasher circuit to simulate each 20 watt bulb.... and away I went. * 1.6 amps through 7 ohms resistance is going to generate some heat so use 20 watt resistance to be safe. You can go higher wattage if you want but 20 minimum. 20 watt bulb 20 watts is 1.66 amps current flow 12 volts/1.66 amps is 7.22 ohms resistance Went back to the incandescent bulbs but still not working Quote Link to comment
datzenmike Posted September 1, 2022 Report Share Posted September 1, 2022 Swap the 4 way with the turn flasher. If the turn starts working then the turn flasher unit was bad. Quote Link to comment
banzai510(hainz) Posted September 1, 2022 Report Share Posted September 1, 2022 is this with motor slightly reved up? Maybe low output alternator Quote Link to comment
Joecar Posted September 1, 2022 Author Report Share Posted September 1, 2022 2 hours ago, banzai510(hainz) said: is this with motor slightly reved up? Maybe low output alternator It does it when the truck is in accessory mode or while running Quote Link to comment
Joecar Posted September 1, 2022 Author Report Share Posted September 1, 2022 2 hours ago, datzenmike said: Swap the 4 way with the turn flasher. If the turn starts working then the turn flasher unit was bad. How can i do that Quote Link to comment
datzenmike Posted September 1, 2022 Report Share Posted September 1, 2022 I think the flasher units are together under the dash beside the steering column. Turn the 4 ways on and follow the clicking. Quote Link to comment
