Bad stock 71 510 Posted August 14, 2022 Report Share Posted August 14, 2022 Bone Stock 71 Datsun 510. does anybody know what would be the easiest way to install a cable onto a original 1600 with a Weber 3234 carb Quote Link to comment
yenpit Posted August 15, 2022 Report Share Posted August 15, 2022 A choke cable? Is the 32/36 carburetor on the car a manual choke? If so, I should have the factory manual choke cable parts...................PM me! You could also go to AutoZone etc & buy a universal fit manual choke cable kit. They are kinda crappy looking, but gets the job done. If the 32/36 is an auto choke, there MIGHT be a kit online to convert to manual (look at Redline or Pierce Manifolds etc), otherwise you would need to replace the carb with a manual carb & cable! 1 Quote Link to comment
Bad stock 71 510 Posted August 17, 2022 Author Report Share Posted August 17, 2022 Wow thanks for the reply I was looking for a fix for missing linkage and a throttle cable. I wasn't clear on my description. This is my first post 1 Quote Link to comment
banzai510(hainz) Posted August 17, 2022 Report Share Posted August 17, 2022 what the bar linkage missing? they usually work with a weber DGV as the dgv came with the other set up. as mine did you need to mod the pedal. the stock pedal has the ball on the end for a rod linkage set up. What I did is cut the end of a another pedal that uses a slot set up and I welded it to my 510 pedal so I can use both. 1 Quote Link to comment
edekalil Posted August 19, 2022 Report Share Posted August 19, 2022 (edited) I had a Weber 32/36 dgv for a long time sitting around that I wanted to use. I also had an adapter plate to mount it on the stock manifold. I had to remove the part that the stock linkage hooked up to on a stock 510 (1600) carb I had an extra sitting around and then mounted it on the 32/36 dgv and hooked it up like a stock carb linkage does. Sorry for the poor pic. Also the choke cable hooks to the carb. It's a bit hard to see but it's in the pic. The hard part was getting the stock linkage hook up part off the original carb cause it's tight to get to the nut holding it on. Edited August 19, 2022 by edekalil Quote Link to comment
DARIN 510 Posted August 19, 2022 Report Share Posted August 19, 2022 On 8/14/2022 at 3:17 AM, Bad stock 71 510 said: Bone Stock 71 Datsun 510. does anybody know what would be the easiest way to install a cable onto a original 1600 with a Weber 3234 carb Do you have any pics so we can see what you’re working with ? Quote Link to comment
