jbirds510 Posted November 11, 2021 Report Share Posted November 11, 2021 So up to mid 70 ive read there are 2 lines, 1 feed and a return, cant figure out which is which..any help would be appreciated..they run top and bottom in the passenger fender well.is the top feed or return? Quote Link to comment
datzenmike Posted November 11, 2021 Report Share Posted November 11, 2021 I get bottom as the fuel feed line to the fuel filter, top is the return. There is also a tank vent line to the flow guide valve but this is located on the driver's side inner fender. All three may be bundles together but it will travel over to the left side at some point. I don't know about the 510 but all other ones I have seen were aluminum tube while the fuel lines were steel. Awww Matt. 2 Quote Link to comment
yenpit Posted November 11, 2021 Report Share Posted November 11, 2021 Agree on top fuel feed, bottom fuel return, but I think that "flow line valve" was later 71-73........?? On the later cars, the "vent line" went from that flow line valve on the drivers side strut tower, down behind that strut tower, under the car, back to the vapor tank above the fuel tank. It was more of a circular flow vs the earlier double back flow 🧐 Quote Link to comment
thisismatt Posted November 11, 2021 Report Share Posted November 11, 2021 2 hours ago, yenpit said: Agree on top fuel feed, bottom fuel return, but I think that "flow line valve" was later 71-73........?? On the later cars, the "vent line" went from that flow line valve on the drivers side strut tower, down behind that strut tower, under the car, back to the vapor tank above the fuel tank. It was more of a circular flow vs the earlier double back flow 🧐 You just disagreed, though... 🤔🥴 1 1 Quote Link to comment
yenpit Posted November 11, 2021 Report Share Posted November 11, 2021 3 hours ago, thisismatt said: You just disagreed, though... 🤔🥴 Yup, I got backwards............and Mike just laughed (emoji) at me.............🙄 1 Quote Link to comment
