dougfj62 Posted September 24, 2021 Report Share Posted September 24, 2021 Took about a day and half of bending, double flaring brakes lines and rerouting in the engine bay. 1000x better the 40 year old lines. Happy with results. 2 Quote Link to comment
DARIN 510 Posted May 27, 2023 Report Share Posted May 27, 2023 What’s up with that idler a brace mounted on the inside of the idler arm ? Lol rake line on the passenger side is pretty all over the place. It should run tightly along the frame. Quote Link to comment
datzenmike Posted May 27, 2023 Report Share Posted May 27, 2023 It's common to brace the steering box to eliminate frame flexing. Probably wouldn't hurt doing the idler arm also. Quote Link to comment
Colbino Posted May 27, 2023 Report Share Posted May 27, 2023 Pretty sure the brace goes on the outside in the wheel well. 1 Quote Link to comment
DARIN 510 Posted May 28, 2023 Report Share Posted May 28, 2023 17 hours ago, datzenmike said: It's common to brace the steering box to eliminate frame flexing. Probably wouldn't hurt doing the idler arm also. Look again. It goes on the outside in the wheel well. Is that how you do yours ? Lol. And I know what that brace does btw. Quote Link to comment
datzenmike Posted May 28, 2023 Report Share Posted May 28, 2023 Is not the brace between the idler and the frame? This would move the idler from it's intended position. Not the end of the world but ... Quote Link to comment
Stoffregen Motorsports Posted May 28, 2023 Report Share Posted May 28, 2023 On 5/26/2023 at 11:40 PM, DARIN 510 said: What’s up with that idler a brace mounted on the inside of the idler arm ? Lol rake line on the passenger side is pretty all over the place. It should run tightly along the frame. I do believe that plate is supposed to be in the wheel well. Also, didn't your mom ever teach you - if you don't have anything nice to say, then don't say anything at all...? 😁 1 Quote Link to comment
