Davidm Posted July 15, 2021 Report Share Posted July 15, 2021 Hi everyone, First off I love the site. It’s been a lot of help keeping my Datsun on the road. I own a 72 620 pickup and its hard to find any good info anywhere else. I recently ran into a problem where my car continually vibrates. I originally thought it was low on oil and maybe a misfire cause of old spark plugs. But it kept getting worse. Turns out my drive train was the problem. Was on my way to work and I heard a loud thud and then dragging. The drivetrain completely separated at the rear end. The u joint snapped and I’ve been looking to buy a new one. Just not sure where I can get the right one that fits my car. If anyone could help me out it would be much appreciated. I’m 21 and this is my first/only car. Not ideal I know, but I love her more than anything and she is what’s keeping me going right now. Been a rough couple of years. here’s a couple flanges I was looking at online. Don’t know if they will fit though this one has two different versions https://zcardepot.com/products/driveshaft-propeller-shaft-yoke-flange-flange-r200?variant=32125644800113 this is the other one https://www.drivetrainamerica.com/spicer-2-2-1989-1310-series-flange-yoke/?=2-2-1989&gclid=EAIaIQobChMIw-3Q3Krl8QIVIAytBh22RwsoEAQYASABEgJju_D_BwE I need the cross piece that goes in between the two joints also. Would this one work? https://www.autozone.com/powertrain/u-joint/p/moog-super-strength-u-joint-377/704927_0_0?cmpid=LIA:US:EN:AD:NL:1000000:CHS:71700000060849129&gclid=EAIaIQobChMIkM6Ht6zl8QIVIAytBh22RwsoEAQYAiABEgJWSfD_BwE&gclsrc=aw.ds was Reading through some of datzenmike’s old posts and he shows how to replace the cross joint. I just need to know if I’m getting the right parts. Thank you David Quote Link to comment
datzenmike Posted July 15, 2021 Report Share Posted July 15, 2021 Generally the U joint gets all the wear (and is replaceable) and the flanges are fine and never need replacing. Unless damaged like this, it's fine. Can you post a picture? Any auto supply store, like NAPA will have what you want for U joint replacement. Try to get the expensive ones with the grease fitting. And made in the US or Japan if possible. Quote Link to comment
Davidm Posted July 15, 2021 Author Report Share Posted July 15, 2021 Can’t figure out how to get a photo on here. The flange is torn apart so I’m definitely going to need a new one. And the pieces holding the cross piece are missing. Ive got the flange and the cross on order and I’m going to see if they are correct. If I could get a pic on here you’d know it’s no bueno. As far as replacing it I know there a certain alignment needed but I don’t really have any help. I did see an old post from you saying how to do it. Quote Link to comment
datzenmike Posted July 15, 2021 Report Share Posted July 15, 2021 The correct parts will go together and be in alignment. So the U joint wore a hole in it??? Quote Link to comment
Davidm Posted July 15, 2021 Author Report Share Posted July 15, 2021 Yup I think the I joint was loose maybe because it was so old and the spacers wore out. Which explains all the vibration. The joint is still intact but really loose. But one of the rings on the flange/yoke broke open and the drivetrain dropped. Its right where it connects to the differential. Quote Link to comment
Davidm Posted July 15, 2021 Author Report Share Posted July 15, 2021 So took a closer look and the flange that is connected to the driveshaft looks like the one in the picture you posted. The ring on the one connected to the differential is snapped open. Does this mean I need a whole new driveshaft. Both flanges look broken Quote Link to comment
Davidm Posted July 15, 2021 Author Report Share Posted July 15, 2021 I can’t find any yoke online that would work. I order some a flange from oreilly but it was the wrong size. I’ve checked autozone and Napa but they don’t seem to have anything either. Kinda shit out of luck right now Quote Link to comment
Davidm Posted July 15, 2021 Author Report Share Posted July 15, 2021 I did find a u joint though Quote Link to comment
datzenmike Posted July 16, 2021 Report Share Posted July 16, 2021 The vibration was the truck talking to you, trying to say something is wrong. Always fix things right away before they get worse. Quote Link to comment
iceman510 Posted July 16, 2021 Report Share Posted July 16, 2021 To add pictures, just make sure they are resized to less than 1 meg or so, and drag them into your response frame. Fairly straightforward. Quote Link to comment
datzenmike Posted July 16, 2021 Report Share Posted July 16, 2021 Some of these are not in a square pattern but a rectangle. The Nissan yoke/flange part number for the early 240z to '75 is 37117-14601. The U joint for it is 37125-14627* The U joint is Nissan part 37124- 14627* and 37124-P3000. This means the 620 U joint will fit the 240z yoke/flange but the bolt pattern is unknown. I don't have the part number for the 620 flange. The 510 also uses the same U joint and flange and the 510 wagon used an H-190 differential (same as the 620) so a good chance the 240z yoke/flange will work on the 620. Quote Link to comment
thisismatt Posted July 16, 2021 Report Share Posted July 16, 2021 Best bet is to find a donor. Post pictures of the differential side and the driveshaft side. Quote Link to comment
Stoffregen Motorsports Posted July 17, 2021 Report Share Posted July 17, 2021 Used OEM parts are always going to be better than new aftermarket. In case you can't find what your looking for, have you ever heard of these guys? - https://www.driveshaftparts.com/ Quote Link to comment
