matrophy Posted May 19, 2021 Report Share Posted May 19, 2021 Max primary resistance of the coil per the FSM for my 86 z24 is 1.27 ohms. I get 1.8 ohms on both and since both have the same reading, I'm wondering if this is significant. 1 Quote Link to comment
banzai510(hainz) Posted May 19, 2021 Report Share Posted May 19, 2021 short out the leads of the meter and if it reads .6 ohms then I wouldnt worry about it. Matter of fact of both read the samde I say the coils are good anyway datzenmike is more a spec on these later trucks 1 Quote Link to comment
matrophy Posted May 19, 2021 Author Report Share Posted May 19, 2021 8 minutes ago, banzai510(hainz) said: short out the leads of the meter and if it reads .6 ohms then I wouldnt worry about it. Matter of fact of both read the samde I say the coils are good anyway datzenmike is more a spec on these later trucks Forgot about checking that on the low setting. It was off 0.6 in fact. That saved me some $$. 1 Quote Link to comment
Charlie69 Posted May 19, 2021 Report Share Posted May 19, 2021 In 50 plus years of working on Datsuns/Nissans I have only come a croos 1 bad factory coil. But it was on a 1980 720 with a matchbox distributor. Quote Link to comment
matrophy Posted May 19, 2021 Author Report Share Posted May 19, 2021 26 minutes ago, Charlie69 said: In 50 plus years of working on Datsuns/Nissans I have only come a croos 1 bad factory coil. But it was on a 1980 720 with a matchbox distributor. I had one in a 56 VW that went out so it's in the back of my mind. I decided to check it out as part of my Weber saga 1 Quote Link to comment
datzenmike Posted May 19, 2021 Report Share Posted May 19, 2021 The L series matchbox are 0.75 to 1.0 ohms. I guess the Z series are 1.0 to 1.25 +-, did not know that. I thought they were all the same. Charlie I have never seen a failed Datsun coil but the one on my 710 did crack at the top near the high tension wire. It tended to spark to the negative terminal a few times then light off the unburned with a backfire out the muffler. Did this at the same place on way to work one fall going around a corner and shift down into second step on gas, bog, bang. It never did it in the summer and I only once drove it that late in the year. I threw a Z series coil on it. Quote Link to comment
