mike Posted December 4, 2008 Report Share Posted December 4, 2008 Sweet, the pics worked!!! Is this a common head? I was looking for a close chamber but came across this on a decent L20 with an uncracked block that I could probably run as is but it looks to have minor scarring on one of the cylinder walls. Not bad but not optimal. I was thinking on putting a z22 rotating assembly (pistons, crank and rods) in the L20 block and figured that this head would keep a friendly compression ratio with the flat top pistons from the z22. Any info on the head would be cool. Quote Link to comment
datsunaholic Posted December 4, 2008 Report Share Posted December 4, 2008 Well, a U67 is probably one of the more common Datsun heads, as it was used on all '75-77 L20Bs Find a U60 head and we'll talk (it's the one casting I have never seen, and I've even seen the Cast Iron L-series head). Quote Link to comment
datzenmike Posted December 4, 2008 Report Share Posted December 4, 2008 Mike, an LZ-22 with that U67 open head and stock 9.32cc dished pistons will have a compression of 9.8 to 1. If you can find flat top pistons the compression jumps to a monster 11.44 to 1!!! Quote Link to comment
