rosso Posted October 23, 2020 Report Share Posted October 23, 2020 Just trying to source a jack for the wagon. I have one but it does not look like the others I have had. It also does not have a block for the front jacking. And an even bigger question - where does this get stored? Owners manual says 2nd crossmember, but no indication if this is under the car or from the front or back. Thanks, you can tell I am getting excited about getting the project running. Quote Link to comment
edekalil Posted October 24, 2020 Report Share Posted October 24, 2020 (edited) I'm not sure but I believe so I have several sedans and a couple of Goons and I think they are all the same. Post a pic of your Jack and it goes under the back set I believe with the pouch of tools the lug wrench and a couple of yellow chauks for the tires there is also a rid and handle to lower the spaire it goes in a hole in the lower area when you open the rear hatch. Edited October 24, 2020 by edekalil Quote Link to comment
datzenmike Posted October 24, 2020 Report Share Posted October 24, 2020 Wagon and sedan scissor jacks are different although they may still work? Wagon and sedan tool bags and hand cranks are totally different. The sedan jack and crank may be the exact same as used on the S10. Canadian sedans have pliers, spanners and a screwdriver that the US sedans do not. The wagon has a solid axle vs. IRS. and maybe this is the difference. Both sedan and wagon have the same lug wrench and wheel chocks. 19 hours ago, rosso said: And an even bigger question - where does this get stored? Owners manual says 2nd crossmember, but no indication if this is under the car or from the front or back. Have a look down on floor in front of driver's seat. On my 710 wagon the scissor jack fits under a clip, then you turn the jack handle to expand it to lock in place. The lug wrench, well mine does, fits along below the driver's door on the floor in two rubber supports. Have a look it may be different. 1 Quote Link to comment
rosso Posted October 24, 2020 Author Report Share Posted October 24, 2020 Thanks, I think there are 5 items for the wagon: 1. the jack and 2. jack extension block (adapter) 3. the jack wind handle comprised of: a. the long rod to insert into the tire lowering mechanism b. the square bar handle to turn rod 4. lug wrench So far I have the long rod stored in the two clips by the driver's footwell.. I have the square bar but nowhere to put it. So I can lower the spare tire but I have no other parts. I will check the driver seat for the bracket tomorrow. Quote Link to comment
edekalil Posted October 24, 2020 Report Share Posted October 24, 2020 Ah Mike thank you for getting it right, I haven't ever put my stuff back where it went since I took it loose. I'll have to find all my jacks and goodies for the cars and put it back where it came from. Thank you again. Quote Link to comment
datzenmike Posted October 24, 2020 Report Share Posted October 24, 2020 3. the jack wind handle comprised of: a. the long rod to insert into the tire lowering mechanism b. the square bar handle to turn rod sure looks like in front of the driver's seat My 710 has a plastic dust cover that fits over the collapsed jack then it's clamped down for storage. I'm missing the hand crank, which should be like yours, but I have a rod but the end is like a hand crank for starting a model A. Have the pouch, chocks and lug wrench. Weird that the Canadian 510 sedans also got a screwdriver, spanners and pliers. I'm looking at the 510 sedan kit and the hand crank is like mine so maybe someone replaced it. Quote Link to comment
KELMO Posted October 25, 2020 Report Share Posted October 25, 2020 FWIW, At the very least, the two rods that are used to lower the spare could very well still be available as the Titan, Frontier, and Xterra all use this same method. I will check to see if this is a valid statement and if it is I will post part #'s. Nissan has a lug wrench that has a square hole that goes over the end of one of the rods for lowering the spare much like the original part. If memory serves, the three parts can be had for somewhere between 30 to 50 dollhairs. Quote Link to comment
datzenmike Posted October 25, 2020 Report Share Posted October 25, 2020 The 510, 610 and 710 wagons (probably others) have a tire let down system with a funnel to guide the square let down rods in as they can't easily be seen to poke at. Good idea to let the spare down once a year to check the pressure and to lube the mechanism. Quote Link to comment
rosso Posted October 25, 2020 Author Report Share Posted October 25, 2020 I have the long rod and handle to let the tire down, I will have to check if it can also be used as the jack handle. I do have the bracket under the driver's seat but I do not have the 510 jack. So ima need one once I have the car on the road. I may need a jack handle, as Dmike describes it like a model A crank. On all my other sedans, this handle was stored in the trunk on the back panel between the taillights with clips. Quote Link to comment
datzenmike Posted October 25, 2020 Report Share Posted October 25, 2020 The square end lowers the tire. The opposite end works the jack using the handle on the sqare end Quote Link to comment
rosso Posted October 25, 2020 Author Report Share Posted October 25, 2020 So that answers that - all I need is the jack and a place to store the square handle. It is a wagon though - lots of space for things... Quote Link to comment
rosso Posted October 26, 2020 Author Report Share Posted October 26, 2020 Now looking for a jack - anyone have one? I will post in the classifieds too. Is the jack the same as the 240-260-280 Z jacks. Like this apparent Z jack listed on ebay: Looks exactly like how I remember my 510 sedan jacks. Quote Link to comment
datzenmike Posted October 26, 2020 Report Share Posted October 26, 2020 The 240/260/280 Z jack is visually the same as the 510 sedan but the wagon jack is different at the top where it touches the car. It's wider and flatter and pretty much like my 710 wagon jack... With cover... Quote Link to comment
