Vriske Posted October 19, 2020 Report Share Posted October 19, 2020 Hows it going Ratsun family, been a member on the site for a year since I've bought my 620 last February. Since I've had it, I've only been able to work on it a few weeks out the year (thanks military). Recently installed a weber carb and since then it doesn't even start. It had the stock carb in place but also ran very roughly. Figured I could do 2 birds one stone on that one, but that wasn't the case. The engine cranks but won't start, fuel is pumping, spark is present, but no combustion. Attempting to crank the engine over results in the carb blowing air and a bit of fuel out the barrels onto the hood. First vehicle I've ever decided to work on from the ground up as a learning experience. Zero experience with carburetors, zero experience as a legit mechanic (I've fixed simple things on my bmw z4 up to control arms and bushing reppacements) and wanted to learn through trial and error with old school cars and trucks. Any and all help and advice would be appreciated. Given by how this forum is, im completely ready for a roast session too. Quote Link to comment
Vriske Posted October 19, 2020 Author Report Share Posted October 19, 2020 Forgot to mention, its a 1974 chassis, with an l20b and 5 speed swapped into it. Ran rough from when I bought it (burned oil, turns out it was missing a rocker arm). Only drove it that one time to get it home and since then its been sitting until I can determine if it can be safely driven with minimal negative damages Quote Link to comment
datzenmike Posted October 19, 2020 Report Share Posted October 19, 2020 Did you pull any plug wires off while doing the swap? Did you replace this rocker arm? Is this a new in the box Weber? and where did you get it? because there are a lot of fake or counterfeit made in china pieces of shit. Quote Link to comment
Vriske Posted October 19, 2020 Author Report Share Posted October 19, 2020 No plug wires removed. Rocker was replaced. Weber new out the box, from redline. Quote Link to comment
datzenmike Posted October 19, 2020 Report Share Posted October 19, 2020 Is the choke closed? Quote Link to comment
Vriske Posted October 19, 2020 Author Report Share Posted October 19, 2020 Its an electric choke, but I havent hooked the wire on it yet. Its currently able to be opened and closed easily Quote Link to comment
datzenmike Posted October 19, 2020 Report Share Posted October 19, 2020 27 minutes ago, datzenmike said: Is the choke closed? But is it closed while trying to start? Quote Link to comment
datzenmike Posted October 19, 2020 Report Share Posted October 19, 2020 he adapter gaskets are good and bolts are tight? Quote Link to comment
gene knight Posted October 19, 2020 Report Share Posted October 19, 2020 (edited) are any of the push rods bent? i had issue with my b210 after i took it to brakes plus to bleed brakes. it ran rough and valve cover bolts were loose and had to adjusted valves cuz some of them were out of adjustment Edited October 19, 2020 by gene knight Quote Link to comment
Vriske Posted October 19, 2020 Author Report Share Posted October 19, 2020 8 hours ago, datzenmike said: he adapter gaskets are good and bolts are tight? Everything's tightened to spec Quote Link to comment
banzai510(hainz) Posted October 19, 2020 Report Share Posted October 19, 2020 (edited) you got spark from the center coil wire to ground? Yes or NO If yes then pour some gas straight in the carb then see if the motor fires up? starting fluid would work lso as enough fumes would get sucked up and fire off if you have spark you have the points gapped? this is a simple fix watch this a couple times and get aqauinted with a L motor https://video.search.yahoo.com/search/video;_ylt=AwrDQ3JfnI1fZwYAf637w8QF;_ylu=c2VjA3NlYXJjaAR2dGlkAw--;_ylc=X1MDOTY3ODEzMDcEX3IDMgRhY3RuA2NsawRjc3JjcHZpZAMuOEZ5RnpFd0xqSGZsR3FnWGU1OE93Y1VNVE13TGdBQUFBQ1BUR0J2BGZyA3lmcC10BGZyMgNzYS1ncARncHJpZAN5NzNzaVFXeFFPS0F6cXFpa0dGeGJBBG5fcnNsdAM2MARuX3N1Z2cDMQRvcmlnaW4DdmlkZW8uc2VhcmNoLnlhaG9vLmNvbQRwb3MDMARwcXN0cgMEcHFzdHJsAwRxc3RybAMyNQRxdWVyeQN2aW1lbyUyMCUyMGhhaW56JTIwZGF0c3VuBHRfc3RtcAMxNjAzMTE2MTQw?p=vimeo++hainz+datsun&ei=UTF-8&fr2=p%3As%2Cv%3Av%2Cm%3Asa&fr=yfp-t&guce_referrer=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&guce_referrer_sig=AQAAALX4UisICtlzUEdgGXcxCwn1nOhQReGnZW4gvGCsDRvTwcQmuhn4Ey0oBiVrCPhcatu6qGy5ifcCtt3o-Nt5aKMj1CHjL3g3BEVuvqfjdXxkKTqsSQtdu377GGIjMfgyIvT2W2uLLWkjwHnLdJ2AKcMBzIBpIR5r7tQ4mTFxZ2bY&_guc_consent_skip=1603116171#id=1&vid=c2bc940e3b3389a9689e968fcaa2fb12&action=view Edited October 19, 2020 by banzai510(hainz) 1 Quote Link to comment
Vriske Posted October 19, 2020 Author Report Share Posted October 19, 2020 Well, I figured it out. One of my buddies working with me forgot to mention that he changed the firing order up. I feel dumb for not having checked that first thing the other day, but it runs and thats what matters.Truck turned right on as soon as that was swapped back. The blowby is the next thing on the list but perhaps thats a topic for another day. Thank you all for your input and advice! 1 Quote Link to comment
vicdat Posted October 19, 2020 Report Share Posted October 19, 2020 Yeah....the old F'up firing order (especially common on an L motor) will bite ya every time.... Vicdat Quote Link to comment
banzai510(hainz) Posted October 20, 2020 Report Share Posted October 20, 2020 Like I said Simple fix Quote Link to comment
datzenmike Posted October 20, 2020 Report Share Posted October 20, 2020 On 10/18/2020 at 6:43 PM, datzenmike said: Did you pull any plug wires off while doing the swap? Did you replace this rocker arm? Is this a new in the box Weber? and where did you get it? because there are a lot of fake or counterfeit made in china pieces of shit. First question. 1 Quote Link to comment
