Lots of work to do on the 720.
None_zero
Regarding metal replacement, I was recently pointed toward this guy, who I have now become a huge fan of.  He uses only the most basic tools and techniques that work well for a large majority of situations.
https://www.youtube.com/watch?v=_u31t13QO6A
  • Replies 102
Yours is a Z20?  That could account for differences. More research on Z20 info is recomended. i've never had a z20, so I can't really offer any good advice regarding that motors particulars.
Hot fucking damn! Boys we have headlights that go bright and dim and parking lights! We have windshield wipers that wipe fast and slow and we've got a blower motor that blows blows hard and blows your damn socks off! Whoohoo!! Only down side for today's progress is wipers dont finish their cycle when you cut them off they just stop wherever they are.
It is a good damn day today!
Wiper "parking" is a specific ground, so you may just not be getting that ground connection when switch is off.
Yes that looks like could be det sensor, good call.
Unplug the oil pressure sensor, start the truck, does the oil light come on for a second?  Now plug it in and see if it comes on.  Also that is simply a ground switch, so if you ground the yellow green wire your oil light should come on.  And with the engine off you should have measurable resistance between where the wire connects to the sensor and the engine block.  With engine running there should be no resistance at all between those two points.
That's the oil low pressure switch just right of the oil filter. It's in the pressure line to the oil filter which is not only not correct but if the filter were to clog it wouldn't warn you of low pressure. It's correct location is that other fitting on the left of the filter that is probably for an oil cooler??? or maybe oil feed for a turbo? Whatever it's for it's a bad idea. The sensor should be put on a TEE fitting if doing this. I would buy a new oil pressure warning switch and put it in the proper location and wire it up. Just leave the other one to fill the hole.
DETONATION SENSOR
Would only be on the Z20 engine on the Mileage Option 720. It should be higher up on the block just under the head and would NEVER be on the oil line up to the head where the warning light sensor switch should be. Look between the two pair of exhaust pipes exiting the head. The engine ID is there just below the head on top edge of block...
Untitled.jpg.ef02d9bfcaed4ec2c55ef323a2f
The fitting top left (with two wires) looks like a temperature switch for turning an electric fan on for the radiator. Again not stock. The temperature gauge sender is just below the thermostat to read the hot water coming out of the engine. This is on the intake which will read much lower and is less accurate for a fan. Do you have electric fans???
DETONATION SENSOR
Ok let me unpack this so
So that port just behind and above the oil filter is not a det sensor? (This is a z20 engine bit not sure about the mileage option how would I know?)
I removed the oil pressure sensor from that hole just to the right of the oil filter. You are saying it shouldn't be there? What kind of a t do you mean? I have zero experience with after market mods all my mechanical learning comes from taking shit apart and figuring out why it doesn't work when it's broken. And this is the deepest I've ever really delved into any vehicle. I have done the light work previously, oil change, brake pads, valve cover gasket. Alternator replacement water pump replacement. Things like that so forgive my ignorance please and explain it like you would for a moron.
Don't remove it. The hole has to stay plugged or oil will spray out. Get a new sender and put it on the left of the filter where that fitting is..
I got a wild hare this afternoon and removed the rad the alternator the batt and cleaned a truckload of oil and grime off the engine so I could more easily find the oil leak I have I suspected it was at the oil pan gasket and i think i was correct. Will I have to remove the transmission to replace that gasket ?
Couldn't I swap the two fittings and cap the unused one?
Yes that would also work. The one on the left is already capped or oil would be coming out when running.
No the transmission is not in the way. The steering and cross brace are in the way.
I thought that might be the case, maybe I was wrong about the oil leak after all. That knock sensor or whatever it is was capped for most of the time I've had the truck but maybe a month or three ago I was doing some work to it and a buddy of mine reached back in there and pulled the cap out and didn't know where he'd pulled it from as it's not terribly visible most of the time. I had forgotten about that but I think that's around the same time I developed the oil leak... jesus
The BSPT was used up well into the 2000s and maybe still used today. In the 50s Nissan built some Austin cars under license and also had access to blueprints and  manufacturing processes and copyrights. The Austin engine was copied and improved and MG engines share a lot of parts with the E and J series engines. The British pipe thread was continued because... they could I guess.
001-mancini-1969-pontiac-grand-prix-sj-f
1969_pontiac_gto_1534981205f66e7dff9f987
1280px-1968_Pontiac_Parisienne_(16322836
Know why the Pontiac has a big nose on the fronts?
I made a filler from sawdust and wood glue to fill the main portion of the deteriorated areas in the dash. I'd already started spreading in into the voids when I remembered to get a "before picture" then i let that cure and filled over that with a water based wood filler and sanded it smooth'ish then I sprayed it matte glacier grey and did a final fill with some light gray dynaflex ultra and and accented the vents and knobs with rustoleums' 2x gloss, the color is "seaside"
