None_zero Posted October 14, 2020 Author Report Share Posted October 14, 2020 (edited) Well I'd I hold my hand in this rattle bag She sounds real nice actually shortly after I posted this it smoothed out and settled into a much less noisy state Edited October 14, 2020 by None_zero 1 Quote Link to comment
None_zero Posted October 14, 2020 Author Report Share Posted October 14, 2020 @datzenmike also I should mention you were right about the sparkplug wires being switched on the coils good call on that. I probably need to redo from the lashing out because it got pretty well cooled down before I really got myself set on what I was doing. It is running though and it sounds better than before it blew that coil wire last time. 1 Quote Link to comment
datzenmike Posted October 14, 2020 Report Share Posted October 14, 2020 13 minutes ago, None_zero said: Ok getting there slowly so my timing is hitting 0 dead on the money to change... (advance?) It to 5 i loosen the dizzy on its bracket and rotate clockwise? Currently near or at op temp setting at 700 rpms max and she sounds decent.i dont know if I'd call this purring but she's doing the damn thing All engines crave to be advanced at idle. When you advance to that 50 the idle speed will most likely speed up. 1 Quote Link to comment
