natin Posted November 28, 2008 Report Share Posted November 28, 2008 I have been thinking about adapting the bosch k-jet mfi system found on 70's-80's volvos, audis, vw's, porsche's, merc's to a L-series motor. it would require custom or modified manifolds but the system is very straight forward. ive seen many toyota 4x4 guys do this on there 22r's. so i know its possible. I want to go this route because i would like to turbo this and not via draw threw sytem or the costly jdm efi. i can buy all the parts needed from the junkyard for well under $100. I was wondering if anyone had any experiance with the system or have done this themselfs. or know of any information that could prove helpfull. thanks. Quote Link to comment
banzai510(hainz) Posted November 29, 2008 Report Share Posted November 29, 2008 Tope End performance has TWM intakes IF YOU JUST GOTTA HAVE IT!!!!!!!! Quote Link to comment
natin Posted November 29, 2008 Author Report Share Posted November 29, 2008 I plan on making custom intake and exhaust manifolds. anyone tried this mfi? Quote Link to comment
datzenmike Posted November 29, 2008 Report Share Posted November 29, 2008 Is this batch fire or sequential FI? The old 20sx was batch fire, firing all injectors every turn of the crank. 1/2 the fuel needed each squirt. Quote Link to comment
natin Posted November 29, 2008 Author Report Share Posted November 29, 2008 it is cis constant injection. controlled by a throttle body. the more air enters tb the more fuel is feed to contant injectors. dont know if that was what u were asking Quote Link to comment
Icehouse Posted November 29, 2008 Report Share Posted November 29, 2008 There is a dude at my work that adapted that FI to a L16 in the 80's he's no longer a Datto guy but has some good stories about that car. I guess it can't be that tough. Quote Link to comment
natin Posted November 29, 2008 Author Report Share Posted November 29, 2008 do you happen to know how it well worked for him? Quote Link to comment
datzenmike Posted November 29, 2008 Report Share Posted November 29, 2008 it is cis constant injection. controlled by a throttle body. the more air enters tb the more fuel is feed to contant injectors. dont know if that was what u were asking Yes, understood. The 200sx used a flapper door like the one you describe but it's not a constant spray and has sensor input to an ECU. Probably a bit more accurate but more stuff to go wrong too. Quote Link to comment
natin Posted November 29, 2008 Author Report Share Posted November 29, 2008 ya this unit has no ecu or wiring for that matter its all mechanical. came on factory turbo volvo's 244 i believe. here is a link to a youtube video of it in action. Quote Link to comment
Icehouse Posted November 29, 2008 Report Share Posted November 29, 2008 Yeah he said it worked fine, I'm with mike though. Using something a little newer with a computer wouldn't be a bad idea since your going to have to make custom parts anyways. Quote Link to comment
Cuts metal like mad Posted November 29, 2008 Report Share Posted November 29, 2008 this is something I considered for awhile, I have some drawings and pics of a manifold design based on the setup off of a rabbit. Would be easy to do, although not very good for turbo it's archaic and inaccurate, when megasquirt came out I quickly lost interest in the idea. Good luck if you decideto do it though would be cool Quote Link to comment
natin Posted November 29, 2008 Author Report Share Posted November 29, 2008 ya i though it would be very diffic with a turbo as well. as for inaccuate the old factory turbo cars with this system had good power and drivability. it cant be much worse than say the old blow threw carb and turbo setup. ive seen two dyno's on toyota 22r's one with a gain of somewhere around 10 hp the other like 17hp over when carbed. so i think its well worth trying. plus it may be very inexpensive. zuum510 did you plan on making the injector bungs or did you ever find a place that sold the bungs? i know you can remove them out of the old manifolds but after that idk. i would like a set to just weld in. Quote Link to comment
Cuts metal like mad Posted November 29, 2008 Report Share Posted November 29, 2008 Never looks into getting bungs, I would have used an old rabbit manifold and maybe a weber sidedraft manifold combo... Quote Link to comment
moparvwfreak Posted November 29, 2008 Report Share Posted November 29, 2008 i too have been toying with this idea. VW CIS-Basic should work just fine. no computers at all like the K-Jetronic has. parts are redily available off a 77-80 rabbit, or scirocco or 80 Jetta. and its easy to tune if you ahve the ear for it. i dont see why it wouldn't work on our motors. as for turbo setups you would also need more fuel for the added air flow but that should be easy to deal with. keep me posted as i have all the parts to run this style system. also EARLY BMW, 190E Mercedes, Volvo 240s, and of course VW had it as well. VW ran it all the way up to 93 in the passats and golfjettas with the 16vs. just a whole lot more wireing on teh CIS-Motronic. Quote Link to comment
natin Posted November 29, 2008 Author Report Share Posted November 29, 2008 ya the parts i plan on gathering will be from a 2.0+ litre turbo motor such as a volvo 244 or saab turbo or 911 turbo. im not going to go crazy on the boost but 10-14 ish psi and monitor it with a wideband and just see what i get if it runs lean i will swap for larger fuel distributor or injectors. the thing is i cant find much info on what cis injectors flow. Quote Link to comment
moparvwfreak Posted November 29, 2008 Report Share Posted November 29, 2008 ya the parts i plan on gathering will be from a 2.0+ litre turbo motor such as a volvo 244 or saab turbo or 911 turbo. im not going to go crazy on the boost but 10-14 ish psi and monitor it with a wideband and just see what i get if it runs lean i will swap for larger fuel distributor or injectors. the thing is i cant find much info on what cis injectors flow. check vwvortex.com. there is a load of good turbo cis info there Quote Link to comment
datsunfish Posted November 29, 2008 Report Share Posted November 29, 2008 I had a cis audi 5000 5 cyl. a few years ago. Never very reliable. Just cut out every so often or wouldnt start. Other than that I loved the car. Like a compact cadillac. I always figured if someone knew how to tune them it would be a cool idea for a L series. Quote Link to comment
moparvwfreak Posted November 29, 2008 Report Share Posted November 29, 2008 I had a cis audi 5000 5 cyl. a few years ago. Never very reliable. Just cut out every so often or wouldnt start. Other than that I loved the car. Like a compact cadillac. I always figured if someone knew how to tune them it would be a cool idea for a L series. tuning is easy. i ahve had an ASSLOAD of experience tuning CIS. all thats needed, for basic anyway, is a good ear, a 3mm allen wrench, and a 13mm wrench to tweak timing. oh and MAYBE, at least on a dub, a 7mm wrench to adjust the idle. but a wideband O2 would be a good thing. Quote Link to comment
