datsuntech Posted November 27, 2008 Report Share Posted November 27, 2008 I am wanting to boost my KA. I want aprox 250-300 reliable hp to the rear wheels. Can this be done to a stock bottom end or do I need pistons? I really like the torque that the car makes and don't really want lag or a drop in power down low. I would like stockish power till about 3-3500 and then have the boost come on. Is this possible or is it just a pipe dream? I really have little experience messing with turbo engines, but I am a mechanic have done a few swaps and have been building datsuns for the last 20 or so years. This is to be my barely streetable/track car. Any help would be appreciated. Brock Quote Link to comment
thisismatt Posted November 27, 2008 Report Share Posted November 27, 2008 From what I've read 300 is more or less the most you'd want to run stock. There's a guy on zilvia selling a KA24E supercharger setup ;) Quote Link to comment
Icehouse Posted November 27, 2008 Report Share Posted November 27, 2008 When I was into the s13 scene I had a buddy who had a stock KA24DE running 12psi, it put down a touch over 300 to the wheels. The head gasket only lasted a few weeks, it sure hauled ass though!!!! I'd think with the right build it would last a long time. Franks KA24E running 6psi lasted a long time, and he was VERY hard on it, his KA also had the stock head gasket. Do a build and keep us updated. Quote Link to comment
NorCalDime Posted November 27, 2008 Report Share Posted November 27, 2008 Average: 300 rwhp to 350 rwhp, you have to start to expect a little more lag. This is about the perfect "street car" limit. No race gas, just good honest street car fun that is fully capable of bring home a 12 second timeslip on a good run. Turbo Manifold T3/T04E .50 Trim compressor, .60 trim compressor housing / Stg 3 (aka TA31) turbine wheel, .48 to .63 A/R exhaust housing. Internal wastegate optional but not recommended. Downpipe can still be 2.5", but this is as far as I would want to push that. Front Mount Intercooler (FMIC) It's time to upgrade to a larger front mount as the larger will push more air than the smaller sidemount can cool. Fuel Control 550cc Injectors SAFC2 to control your fuel injectors, along with the stock ecu. MSD BTM At this stage I would be running the BTM to control timing retard. Reflashed ECU-This can be a DIY thing with Megasquirt Tuning or a JWT. Z32 Maf is required, as the stock Maf stops being able to read at around 260 rwhp. Wideband O2 Sensor should be installed for tuning. Block Internals This is where I would start to consider it necessary to replace you pistons. But not required Above Average: 350 rwhp to 425 rwhp Turbo Manifold Blow Off Valve T3/T04E 50 Trim .48/.63 or slightly larger turbo, this is where I would start to make the switch up to an external wastegate. You have the option to reroute it back into the exhaust, or merely "dump" it out into the open. "Dump" is usually a mini exhaust in the form of 1.5" piping routed out to the open. FMIC Larger is starting to be necessary. Typical for setups from here on, are 12"x24"x3" for the core. Downpipe 3", at this point I would switch to the larger downpipe. You can probably get away with it at 2.5", but it will be causing a little bit of backpressure. Moving to 3" piping as quickly as possible is what you want though. Usually it is necessary to have the first bend 2.5" to clear the steering shaft though. Exhaust 3" Block Internals At this stage you'll want to "build" or fortify your block to better handle boost. Previous to this you can walk the line, but here and forward I find it necessary to do so. Forged Rods Forged Pistons Stock Crank Plus your typical rebuild items. Fuel Control Standalone fuel management is recommended at this stage in the game and is absolutely necessary at the next. These allow you control not only very large injectors, but the tuner to have complete control over both timing and fuel. 720cc Injectors. Wideband O2 Sensor is necessary for tuning. Quote Link to comment
DISLEXICDIME Posted November 27, 2008 Report Share Posted November 27, 2008 sounds like my starion's boosted 2.6. it is a lot of fun at stock boost (7pounds) its pushing 233 pounds of torque and 188 horses i imagine a boosted ka would be about the same. but in a car 1000 pounds liter now that sounds like fun . i always figured the extra torque from the ka would give a stock sr a run for its money stop light to stop light Quote Link to comment
datzenmike Posted November 27, 2008 Report Share Posted November 27, 2008 Could I ask something? Will a stock KA E accept any boost without changing the stock sensors and ECU? If it will, how high will it go before some form of extra fuel management is needed. Quote Link to comment
Guest DatsuNoob Posted November 28, 2008 Report Share Posted November 28, 2008 I imagine you'd just have to change up to a high flow fuel rail, and bigger injectors, bigger MAF, and tinker with the ECU settings a bit. My buddy Matt had his uncle (mechanic) tune the stock computer on his Neon to dump more fuel on a N/A 2.0L with one of those Sunpro diagnostic computer controllers. Maybe that and a wideband O2 controller could work? I'm sure Fineline made his work without spending a million dollars. Quote Link to comment
datzenmike Posted November 28, 2008 Report Share Posted November 28, 2008 I guess what I'm asking is how much before the stock system isn't enough? 4, 6, 8lb of boost? Less? Quote Link to comment
DISLEXICDIME Posted November 28, 2008 Report Share Posted November 28, 2008 datzen mike its in here some where i for get where http://www.ka-t.org/forums/ Quote Link to comment
datzenmike Posted November 28, 2008 Report Share Posted November 28, 2008 Thanks...... for the spankin'. That was like being sent to the search room:D Wow 3 1/2 hrs later I think I have a very (small) grasp on it. Looks like a small boost is acceptable, but it can quickly run out of fuel top end due to injector size. The problem is no one wants a little boost.:lol: Thanks again for directions. Quote Link to comment
Icehouse Posted November 28, 2008 Report Share Posted November 28, 2008 I guess what I'm asking is how much before the stock system isn't enough? 4, 6, 8lb of boost? Less? Frank was running 6psi with only an SAFC2, it hauled ass!!! Thinking about boosting your truck? Its a 2.2 right? I think you should get the SR EFI and sensors, it would be ready for boost and all the maps would be much closer than the KA stuff. Shit up in Canada that shit is cheap too!!! Quote Link to comment
datzenmike Posted November 28, 2008 Report Share Posted November 28, 2008 Frank was running 6psi with only an SAFC2, it hauled ass!!! Thinking about boosting your truck? Its a 2.2 right? I think you should get the SR EFI and sensors, it would be ready for boost and all the maps would be much closer than the KA stuff. Shit up in Canada that shit is cheap too!!! Hi Jeff. Well not likely but who doesn't think about things. It's a Z24 right now but hopefully will have KA24E EFI next summer. What about '85 CA18ET ECU and sensors or are they still the old batch fire Bosch type? Quote Link to comment
datsuntech Posted December 3, 2008 Author Report Share Posted December 3, 2008 sounds like my starion's boosted 2.6. it is a lot of fun at stock boost (7pounds) its pushing 233 pounds of torque and 188 horses i imagine a boosted ka would be about the same. but in a car 1000 pounds liter now that sounds like fun . i always figured the extra torque from the ka would give a stock sr a run for its money stop light to stop light When I was a kid my brother had a Plymouth Sapporo with the 2.6 in it. Hauled ass whole lota torque. I always loved the Starion, but we never got them up here in Canada. That's exactly what I want....lots of torque down low with plenty of power up top too. You know, the best of both worlds. Brock Quote Link to comment
