Charlie69 Posted June 4, 2020 Report Share Posted June 4, 2020 (edited) Read my post above. I run nothing but Webers and have been doing so since the early 70s. I would order throttle shaft and roller bearings and install them while you have the carb off. The Itallian made Webers are rare now. I have been buying new Webers for about the last 10 years for my trucks. Years ago I would buy used Webers from the junk yards. Also would buy SUs for my Harleys from the junk yards. Edited June 5, 2020 by Charlie69 1 Quote Link to comment
bottomwatcher Posted June 4, 2020 Report Share Posted June 4, 2020 Like Charlie said. Use the straw on the carb cleaner and spray all mating surfaces and the ends of the shafts if the carb has high miles. Do this while the engine is running. If there is a change in rpm you have found a vacuum leak. 2 Quote Link to comment
jamesh Posted June 21, 2020 Author Report Share Posted June 21, 2020 Better late than never. tested for vacuum leaks and everything was good. i installed redline part no. 99007.115 it is a throttle adapter kit. I want to do a write up on this, and how I installed it, but I cannot say enough positive things about it. This took my truck from being something incredibly difficult to drive, to having an accelerator pedal that feathers like a dream. No roller bearings needed, at least not yet. it was relatively easy to install, and it repositioned the throttle pull toward the driver side of the truck (factory has it pulling toward the passenger side). Only slight modification necessary. truck running pretty wel, none of the solenoid cut offs I bought seem to thread into my carburetor, the choke assembly is way to close, and the thread size for the primary choke is the same as the secondary, so maybe there is no part for this particular carburetor. Any leads on this would be helpful. still dieseling but suspecting that jets need to be adjusted slightly, possibly downsizing the idle stream, and even the main jet to make a more lean condition. will post on throttle adapter soon! 1 Quote Link to comment
Charlie69 Posted June 21, 2020 Report Share Posted June 21, 2020 I use the throttle plate of the stock carb never had an issue, but I always run a lite return sprng also. Quote Link to comment
waddlin Posted October 27, 2021 Report Share Posted October 27, 2021 On 6/21/2020 at 10:16 AM, jamesh said: Better late than never. tested for vacuum leaks and everything was good. i installed redline part no. 99007.115 it is a throttle adapter kit. I want to do a write up on this, and how I installed it, but I cannot say enough positive things about it. This took my truck from being something incredibly difficult to drive, to having an accelerator pedal that feathers like a dream. No roller bearings needed, at least not yet. it was relatively easy to install, and it repositioned the throttle pull toward the driver side of the truck (factory has it pulling toward the passenger side). Only slight modification necessary. truck running pretty wel, none of the solenoid cut offs I bought seem to thread into my carburetor, the choke assembly is way to close, and the thread size for the primary choke is the same as the secondary, so maybe there is no part for this particular carburetor. Any leads on this would be helpful. still dieseling but suspecting that jets need to be adjusted slightly, possibly downsizing the idle stream, and even the main jet to make a more lean condition. will post on throttle adapter soon! Did you ever do a write up post on the throttle adapter? Quote Link to comment
