Jordanpietak Posted January 16, 2020 Report Share Posted January 16, 2020 Hello all, I am in need of assistance, the front pinion on my truck broke and I am having issues finding a new one. Is there a site that sells new parts or is this something I will need to find used? any info will help 1 Quote Link to comment
datzenmike Posted January 16, 2020 Report Share Posted January 16, 2020 If 2wd the H-190 has a bolt in removable ring and pinion 3rd member. Looks something like this... By unbolting the axles and pulling them out to the sides to disengage the side gear splines, the H-190 gear set can be unbolted from the axle housing as a unit and replaced. You can find them used in wrecking yards for $50- $100. You might even try a want ad in the classifieds... https://ratsun.net/classifieds/category/9-datsun-parts/ ... but you will need to specify the ratio you want and where you want it sent to for shipping costs. To find the ratio look on the outer rim of the ring gear when you take it out. It might have stamped on it 35/8 or 35 divided by 9= 3.889. Alternatively look on the engine tag on the passenger side inner fender just below the hood hinge. On the bottom line it says TRANS/AXLE.... FS5W71B (or L3N71B if automatic) ...... HF38. The 38 identifies it as a 3.889 differential. A 37 would be a 3.700 and a 35 a 3.545 and so on. You can't get just a pinion from Nissan but the R&P only as a set and nearly $700. Get one from a wreckers. 1 Quote Link to comment
Charlie69 Posted January 17, 2020 Report Share Posted January 17, 2020 There is a rare 3.33 ratio used in the mileage 720 ttrucks with the 720. Quote Link to comment
Stoffregen Motorsports Posted January 18, 2020 Report Share Posted January 18, 2020 Try https://www.differentials.com/ or https://www.randysworldwide.com/product-category/ring-pinion-gear-sets?gclid=EAIaIQobChMIrJzDuMaN5wIViobACh3MzghcEAAYASAAEgL24PD_BwE 1 Quote Link to comment
Charlie69 Posted January 18, 2020 Report Share Posted January 18, 2020 Nissan/Datsun is nit in randysworldwide.com webpage drop down menu for auto manufacturer selection. Quote Link to comment
wayno Posted January 18, 2020 Report Share Posted January 18, 2020 (edited) OK, I may be understanding this wrong, is the original poster talking about the front or rear differential/gears? Edited January 18, 2020 by wayno 2 Quote Link to comment
datzenmike Posted January 18, 2020 Report Share Posted January 18, 2020 I was thinking the front of the pinion. Well same advice replace the R-180 as a unit. Buying a gear set is expensive and these (R-180) need a mechanic with specialized tools to set all the clearances. 1 Quote Link to comment
