Elbocho74 Posted November 30, 2019 Author Report Share Posted November 30, 2019 20 minutes ago, wayno said: Matchbox distributor with EI coil. Where and how can I find the right match ( what is a match box. Sorry Im new with Datsuns) whay brand and specs coil. Can I use my MSD2. 1 Quote Link to comment
datzenmike Posted November 30, 2019 Report Share Posted November 30, 2019 1 hour ago, Elbocho74 said: You are right my points are fouled. My coil is .07 ohm and requires a .8 ohm resistor. Now that I saw the engine running. Im considering set it up with an electronic ignition system. What set up could I use for electronic ignition. Could you list the part numbers. I would like something reliable but not too expensive. As long as you have points you need to limit the current flow through them. The coil and the ballast resister should total about 3 ohms. If the coil you have is 0.7 then you need about a 2.5 ohm ballast. That 0.7 ohm coil would work with an electronic ignition. That said for now until you can find an EI, (electronic ignition) get a new coil, and a ballast resister to match, for a points distributor, like a '77 200sx. NAPA will probably have a replacement but it must be for a points distributor. Here are the part numbers, perhaps they can use them to cross reference another make. Coil......... 22448-U6702 Ballast... 22460-U2200 Try a want ad here... https://ratsun.net/classifieds/category/9-datsun-parts/ ... All you need is a coil and a ballast for any Datsun before '78. The 'matchbox' is a second gen EI distributor that has a miniaturized 'little black box" igniter module on the side. They were introduced in all '79 vehicles and used in the L series distributors through '80. Keep your 'master blaster' 0.8 ohm coil, it will work perfectly with a matchbox. The perfect answer would be to get the 8 plug Z24 distributor and use all those plugs. It's the 3rd generation EI with the module inside under the rotor. It's what is supposed to be on there with an 8 plug head.. 1 Quote Link to comment
Elbocho74 Posted December 1, 2019 Author Report Share Posted December 1, 2019 19 hours ago, datzenmike said: As long as you have points you need to limit the current flow through them. The coil and the ballast resister should total about 3 ohms. If the coil you have is 0.7 then you need about a 2.5 ohm ballast. That 0.7 ohm coil would work with an electronic ignition. That said for now until you can find an EI, (electronic ignition) get a new coil, and a ballast resister to match, for a points distributor, like a '77 200sx. NAPA will probably have a replacement but it must be for a points distributor. Here are the part numbers, perhaps they can use them to cross reference another make. Coil......... 22448-U6702 Ballast... 22460-U2200 Try a want ad here... https://ratsun.net/classifieds/category/9-datsun-parts/ ... All you need is a coil and a ballast for any Datsun before '78. The 'matchbox' is a second gen EI distributor that has a miniaturized 'little black box" igniter module on the side. They were introduced in all '79 vehicles and used in the L series distributors through '80. Keep your 'master blaster' 0.8 ohm coil, it will work perfectly with a matchbox. The perfect answer would be to get the 8 plug Z24 distributor and use all those plugs. It's the 3rd generation EI with the module inside under the rotor. It's what is supposed to be on there with an 8 plug head.. Hello Im in the proces to finding the Coil and resistor combination totaling 3 ohms. I came across of a Per Tronix 1741 ignitor for 4 cylinders Datsun. Would you recomend this to replace my points. 1 Quote Link to comment
datzenmike Posted December 1, 2019 Report Share Posted December 1, 2019 Don't know how much current they will handle. You may still need the ballast. Hainz would know. You might be able to use the PerTronix unit to run an HEI module from an older GM distributor. Essentially making your distributor an EI. 1 Quote Link to comment
Crashtd420 Posted December 1, 2019 Report Share Posted December 1, 2019 I have always read you want to keep the points coil and ballist resistor with the pertronix... If you decide to use the pertronix make sure the distributor your using was originally set up for single points.... you can eliminate the 2nd set of points from a dual points distributor, and the pertronix doesnt fit that type of distributor..... 2 Quote Link to comment
datzenmike Posted December 1, 2019 Report Share Posted December 1, 2019 22448-U6702 is a Nisan part number for the coil and ballast assembly for a points distributor on a '77 200sx. You may be able to find another part using this number. Has to be for Nissan vehicles before '78. 1 Quote Link to comment
Elbocho74 Posted December 7, 2019 Author Report Share Posted December 7, 2019 Thak you all for all the imput. I went to the juk yard and found a 3.3 Ohm coil from a volvo, took it home. Installed it and replaced my points and condenser, re set my timing and got the truck running Thank you all. I will start a complete inspection on the truck and will start rebuilding the suspension and brakes. Cheers. On 11/27/2019 at 4:15 PM, bilzbobaggins said: Out of curiosity, why did you drop the E.I. dizzy and go with On 11/27/2019 at 4:15 PM, bilzbobaggins said: Out of curiosity, why did you drop the E.I. dizzy and go with 3 Quote Link to comment
Elbocho74 Posted December 18, 2019 Author Report Share Posted December 18, 2019 On 11/29/2019 at 8:53 PM, datzenmike said: As long as you have points you need to limit the current flow through them. The coil and the ballast resister should total about 3 ohms. If the coil you have is 0.7 then you need about a 2.5 ohm ballast. That 0.7 ohm coil would work with an electronic ignition. That said for now until you can find an EI, (electronic ignition) get a new coil, and a ballast resister to match, for a points distributor, like a '77 200sx. NAPA will probably have a replacement but it must be for a points distributor. Here are the part numbers, perhaps they can use them to cross reference another make. Coil......... 22448-U6702 Ballast... 22460-U2200 Try a want ad here... https://ratsun.net/classifieds/category/9-datsun-parts/ ... All you need is a coil and a ballast for any Datsun before '78. The 'matchbox' is a second gen EI distributor that has a miniaturized 'little black box" igniter module on the side. They were introduced in all '79 vehicles and used in the L series distributors through '80. Keep your 'master blaster' 0.8 ohm coil, it will work perfectly with a matchbox. The perfect answer would be to get the 8 plug Z24 distributor and use all those plugs. It's the 3rd generation EI with the module inside under the rotor. It's what is supposed to be on there with an 8 plug head.. Hey Mike, I ordered the 8 plugs distributor, rotor, cap and cables. I understand that if I have the points ignition sysytem, I will need a coil with a ballast resistor totaling 3 ohms. Since Im installing the pulse controlled ignition system as this z20 should have, I have my .8 ohm high voltage coil, do I still need the resistor? If so how many ohms resistor should be. Now I also have a Beru 3.3 ohm wich in the mean time I would like to istall it as the second coil, will this safely work.? 1 Quote Link to comment
datzenmike Posted December 18, 2019 Report Share Posted December 18, 2019 Is this a stock 8 plug wire distributor for a Z series engine? If yes the 0.8 ohm coil will be all you need. 1 Quote Link to comment
Charlie69 Posted January 29, 2020 Report Share Posted January 29, 2020 I have a spare set of used factory coils. If interested PM me. Quote Link to comment
