Thegreek Posted November 30, 2018 Report Share Posted November 30, 2018 Hey guys...new to the forum. So I bought the 620 2 months ago from someone in Jersey who drove the truck here from Washington state on a rebuilt motor with only 20 miles on it. Dealing with some Weber issues at the moment, but plan on dropping it, minor body work, paint, and basic interior work. Quote Link to comment
Thegreek Posted November 30, 2018 Author Report Share Posted November 30, 2018 2 Quote Link to comment
Seeker > 620 KC Posted November 30, 2018 Report Share Posted November 30, 2018 Nice truck. What size rims and tires are those? 1 Quote Link to comment
Crashtd420 Posted November 30, 2018 Report Share Posted November 30, 2018 Looks good.. welcome to the party... 1 Quote Link to comment
Thegreek Posted November 30, 2018 Author Report Share Posted November 30, 2018 12 minutes ago, Seeker > 620 KC said: Nice truck. What size rims and tires are those? Off a Silverado, 225/60/15 Quote Link to comment
Thegreek Posted December 3, 2018 Author Report Share Posted December 3, 2018 Did some adapter tightening last night and replaced a crack plate....purrs like a kitten now....the bolts in the adapter came loose....REALLY loose.... Quote Link to comment
Thegreek Posted December 15, 2018 Author Report Share Posted December 15, 2018 So today I changed out my speedometer cable to one off ebay....and now I know how slow I'm going!!!!!!! The original was broken about 2 foot from the speedometer. It also had all kinds of casing over it I guess for heat protection....I tried to slide them off and put on the new one but they wouldnt clear the fittings. Quote Link to comment
datzenmike Posted December 15, 2018 Report Share Posted December 15, 2018 Insulation looks stapled on. You could do the same if you took apart. 1 Quote Link to comment
Thegreek Posted December 23, 2018 Author Report Share Posted December 23, 2018 Yesterday my fuel pump came.....Spectra Premium SP1174MP....says it's a genuine OEM replacement pump. 1 Quote Link to comment
datzenmike Posted December 23, 2018 Report Share Posted December 23, 2018 OEM refers to the original equipment maker of the part for Nissan. Pretty sure this will not be the case here. Probably says: ' OEM quality' if the pump is built to, or exceeds the same quality standards as the original. The original fuel pump should look like this and be made by Nicco? certainly made in Japan. Quite possibly you will get this. I see lots of them on L series. 2 Quote Link to comment
Thegreek Posted December 24, 2018 Author Report Share Posted December 24, 2018 4 hours ago, datzenmike said: OEM refers to the original equipment maker of the part for Nissan. Pretty sure this will not be the case here. Probably says: ' OEM quality' if the pump is built to, or exceeds the same quality standards as the original. The original fuel pump should look like this and be made by Nicco? certainly made in Japan. Quite possibly you will get this. I see lots of them on L series. Absolutely right...and truck seems to run fine....but I do want to maybe rebuild the old pump....says made in Italy.. Any ideas if they make a rebuild kit for this one? 1 Quote Link to comment
sebpv Posted December 25, 2018 Report Share Posted December 25, 2018 (edited) open it up and see what you might need. Most often its only a paper gasket Edited December 25, 2018 by sebpv 1 Quote Link to comment
datzenmike Posted December 25, 2018 Report Share Posted December 25, 2018 1/ It's definitely not a stock Hitachi pump so you're on your own. 2/ Don't fix what isn't broken. 1 1 Quote Link to comment
Thegreek Posted January 25, 2019 Author Report Share Posted January 25, 2019 So today was a good day. Changed all three u-joints, carrier bearing, and output shaft seal. Changed tranny fluid, rear diff fluid, and oil & filter. Tomorrow I'm swapping out the 79 grill with an early grill...pics to follow. 1 Quote Link to comment
Thegreek Posted February 8, 2019 Author Report Share Posted February 8, 2019 Before and after grill pics..... 2 Quote Link to comment
datzenmike Posted February 9, 2019 Report Share Posted February 9, 2019 Yeah, that's way better. Nissan changed the grill to make it more break resistant but fucked the looks up. Changing to an older grill was one of the first things I did on my '78. 2 Quote Link to comment
