obrut Posted November 13, 2018 Report Share Posted November 13, 2018 I have a cam that I don't have any specs on. It is for a 4 cylinder L series, it has no oil holes drilled in the lobes and has a red stripe on it. The cam is marked 420 00 on the back and looks like it has provision for mechanical tach drive. It does have the two large squares like a L20B cam. The other markings on the cam are CWC I-5 0-1 K 304 D1 I will try and post some pictures when I find a place to host them, thanks for any help Quote Link to comment
banzai510(hainz) Posted November 13, 2018 Report Share Posted November 13, 2018 CWC usually means its a new cam casting. As I have a Schneider and it has a CWC. Mech tach drive. I heard of these . If no holes in cam lobes then it needs a Spray bar. Just me I wouldn't use it, as I have other cams here. But cost of converting your valve cover for this and piping. 420 might be lift x 1.50 304 might be duration But all a guess Quote Link to comment
G-Duax Posted November 13, 2018 Report Share Posted November 13, 2018 I'm with Hainz on that one (hot race cam), but only a degree wheel will say for sure. Definitely not a street cam, and would need really good springs, higher compression pistons, and really good rods to run to it's potential, with out grenading your engine. Quote Link to comment
Stoffregen Motorsports Posted November 14, 2018 Report Share Posted November 14, 2018 Is it marked with electric pencil or is it stamped? Easy enough to measure lift with a pair of calipers. Sounds like a Cal Cams cam to me, but undrilled... ? Race came for sure. And tach drives were popular way back in the 70's and 80's so it may be a piece of vintage racing history you've got there! Now here's a gross generalization that can help when deciding to use a cam or not: a large cam ground for an L16 is going to be "smaller" when used in a larger engine Quote Link to comment
obrut Posted November 14, 2018 Author Report Share Posted November 14, 2018 Here are some pics I was going to run this with a 240z oil spray bar which I already have I just need to shorten it. Quote Link to comment
G-Duax Posted November 14, 2018 Report Share Posted November 14, 2018 This is what I run, been on there for a year or so now. Spring clamps are the double layer type that Toyota uses on some of their FI applications. Hose is FI hose. Just went under the cam cover last week to check valve clearance, and nothing had moved. Quote Link to comment
obrut Posted December 13, 2018 Author Report Share Posted December 13, 2018 So I measured the cam lobe and its 1.465" and the base circle is 1.055 so that's .410" lift. Is that the lift or is it .410" x 1.5 for the rocker arms and then its .615" lift? I thinks its .615 because my L18 cam is 1.585 - 1.300 = .285 x 1.5 = .427 My l16 cam measures 1.575 - 1.300 = .275 x 1.5 = .412 which seem to line up with the specs in the books. Quote Link to comment
banzai510(hainz) Posted December 13, 2018 Report Share Posted December 13, 2018 Thats correct. really its about 1.48 on the rocker ratio.but 600 is pretty big lift. Quote Link to comment
