motavated Posted November 9, 2008 Report Share Posted November 9, 2008 (edited) I took of my 1974 620 headlight switch off and I dont know how to put it back! It has like this metal box, headlight switch, the screw, and a plastic spacer. How does it go together? I'm a missing something? Thanks! Edited November 9, 2008 by Motavated Quote Link to comment
datzenmike Posted November 9, 2008 Report Share Posted November 9, 2008 On my '78 I think you pull the shaft on the switch to the on position, push it through the dash hole, screw the washer on, then grab the shaft with needle nose pliers so it can't move, put the knob over the end, push in and twist to lock it in place. Make sure and turn the knob so the image on it is the right way up.:D Quote Link to comment
motavated Posted November 9, 2008 Author Report Share Posted November 9, 2008 But what about that metal box? It came off from there.... I guess I will have to install it that way since I dont know how that metal box is installed. Quote Link to comment
tdaaj Posted November 11, 2008 Report Share Posted November 11, 2008 show a picture of what you are talking about please? Quote Link to comment
datsunaholic Posted November 11, 2008 Report Share Posted November 11, 2008 Metal box? The headlight switch (on a '73-74) is the switch unit itself (includes the wiring pigtail with the 6-plug connector), a plastic spacer, the locknut, and the knob. Quote Link to comment
DanielC Posted November 11, 2008 Report Share Posted November 11, 2008 (edited) I have a couple of 521 pickups. The three switches on the dash are similar in design and mounting. They all have a switch body that holds the wires, and a threaded part that goes through the hole in the dash, and a chrome nut that threads on to the threaded part. On some switches, the shaft moves in and out, on others the shaft turns, or sometimes both. There is a screw that goes up into the shaft that holds the knob on to the switch. Your headlight switch prrobably mounts the same way as the heater fan switch mounts to the dash. On my 521's there is also a plastic spacer. The plastic spacer goes on the switch first. Then you insert the switch threaded part through the hole in the dash, without dropping the spacer. A thin washer then goes over the threaded part, and then the chrome nut screws down, holdintg the switch body against the spacer on the backside of the dash. Then the knob is installed. I used a little WD-40 on the switch shaft where it goes into the switch mount, (the threaded part). I sprayed the WD-40 on the shaft of the switch, worked the switch several times, and got some gunk out of the switch, wiped that off with a clean rag, reapplied the WD-40, and repeated working the switch, and wiping the dirty gunk off, until the switch shaft is clean. The switches work a lot easier now, and there is less of a chance of breaking the knobs. Edited November 11, 2008 by DanielC Quote Link to comment
Phlebmaster Posted November 11, 2008 Report Share Posted November 11, 2008 Does it look like either of these? Quote Link to comment
