tgaydos Posted May 20, 2018 Report Share Posted May 20, 2018 Starting a build thread for my truck. I'm looking for suspension upgrades. I's a 1984 nissan 720 i got the shell for free picked up a ka sohc for it going to rebuild it and put it in. i'll get pics up this afternoon after work. 3 Quote Link to comment
Stoffregen Motorsports Posted May 20, 2018 Report Share Posted May 20, 2018 Cool. We all love a good build thread. Start off the thread properly with some pics. We love pics too... 2 Quote Link to comment
tgaydos Posted May 21, 2018 Author Report Share Posted May 21, 2018 This is how i got the truck no motor/trans/drive line. got it home and cleaned up a bit, got some new fenders, hood, and dash from the junkyard for reasonable price and polished them up. I got the ka24e from a guy in olympia for $375 stuffed it in the back of my subaru and brought it home. Started tearing it down and only ran into a little trouble with the front intake stud. but i was able to get the stud out with a little work. The engine is completely torn down to bare block as of now. waiting to be able to order a new rebuild kit for it. I'm going to replace the bearings, pistons, gaskets, etc... not sure yet if i want to replace the rods or not they seem fine and i'm not really going to be building this engine for boost. that will be the next one that will replace this ka. Before i can start putting it back together i need to find someone locally (astoria or) that will hot tank the block and probably the head for me. 3 Quote Link to comment
Stoffregen Motorsports Posted May 21, 2018 Report Share Posted May 21, 2018 Looking great so far. 1 Quote Link to comment
tgaydos Posted May 21, 2018 Author Report Share Posted May 21, 2018 main and rod bearings have been ordered. any suggestions on a decent flywheel looking for a mix of lightweight that won't break the bank. found one on autozone website that's 16lbs for 200. 1 Quote Link to comment
Charlie69 Posted May 22, 2018 Report Share Posted May 22, 2018 Do not forget the steel plate that goes behind the flywheel. Quote Link to comment
Stoffregen Motorsports Posted May 22, 2018 Report Share Posted May 22, 2018 What brand of bearings did you order? Hopefully not King. Have your stock flywheel lightened. Any good machine shop can do it. 1 Quote Link to comment
tgaydos Posted May 22, 2018 Author Report Share Posted May 22, 2018 good idea. 2 Quote Link to comment
tgaydos Posted May 22, 2018 Author Report Share Posted May 22, 2018 Do not forget the steel plate that goes behind the flywheel. what's that part called? i can't seem to find it. 1 Quote Link to comment
tgaydos Posted May 23, 2018 Author Report Share Posted May 23, 2018 thank you, i've been looking for a break out like that. 1 Quote Link to comment
Charlie69 Posted May 23, 2018 Report Share Posted May 23, 2018 https://www.nissanpartsdeal.com/ Save image, upload image to your picture host, post picture from your host into your post. Quote Link to comment
tgaydos Posted May 23, 2018 Author Report Share Posted May 23, 2018 got an intake, wiring harness, ecu, maf, and ignitor from a car for $100 today i'd call that a score. almost ready to start putting it back together. 3 Quote Link to comment
bottomwatcher Posted May 24, 2018 Report Share Posted May 24, 2018 Damn it took me years to get to that stage. Keep it up! 2 Quote Link to comment
Stoffregen Motorsports Posted May 24, 2018 Report Share Posted May 24, 2018 Nothing like doing it. Words without action are so boring. BTW - Post more pics!!! If this is going to be one of those good action threads, I want to see lots of pics. 1 Quote Link to comment
tgaydos Posted May 24, 2018 Author Report Share Posted May 24, 2018 i need to get a gasket kit still and pistons. but i got a fat speeding ticket on the way home so that pushes me back about a week or two. oh well. 2 Quote Link to comment
tgaydos Posted May 25, 2018 Author Report Share Posted May 25, 2018 got the new main bearings in, boy does the crank spin good. 2 Quote Link to comment
Stoffregen Motorsports Posted May 26, 2018 Report Share Posted May 26, 2018 One very easy trick to help with rod bearing life is to drill the #2 and #4 main bearing oiling hole to 1/4". Yes, drill the passage in the block and in the rod bearing. Since the rods get their oil from these oil galleys, making them larger helps give them a bit more oil, making them last longer under hard use. Be sure to chamfer the holes in the bearings and the galleys when done. And I assume you have the main oil galley plugs out, so be sure to scrub out the chips before assembly. Also, did you check the crank thrust while you had it mocked up? 1 Quote Link to comment
tgaydos Posted May 31, 2018 Author Report Share Posted May 31, 2018 got the engine mostly put back together today just need to finish putting the accessories back on but before i do that i might want to find my power steering pump bracket.. once i get the trans, engine rear plate, clutch/flywheel it'll be ready to drop in. i suppose i could have been a bit more careful in the teardown. 1 Quote Link to comment
tgaydos Posted June 1, 2018 Author Report Share Posted June 1, 2018 what's everyone running or recommend for fuel pump? 1 Quote Link to comment
Charlie69 Posted June 1, 2018 Report Share Posted June 1, 2018 I run factory or the Facet for carbureated. 1 Quote Link to comment
tgaydos Posted June 1, 2018 Author Report Share Posted June 1, 2018 I need a high pressure I forgot to mention that. It's a ka24e. 2 Quote Link to comment
