tgaydos Posted June 2, 2018 Author Report Share Posted June 2, 2018 Thanks clumsy bird. I do a bit of blacksmithing. 1 Quote Link to comment
Charlie69 Posted June 2, 2018 Report Share Posted June 2, 2018 Hopefully Degaux or distributor guy or Hose stop will chime in. At this time I am only running low pressure carbed. I was not sure if you were going to carb your KA. Farmer Carbed his KA. Quote Link to comment
ClumsyBird Posted June 2, 2018 Report Share Posted June 2, 2018 Looks well used! I can appreciate a good London pattern haha 1 Quote Link to comment
tgaydos Posted June 2, 2018 Author Report Share Posted June 2, 2018 Looks well used! I can appreciate a good London pattern haha that one there is my mentors mine is on the other side of his just out of frame also well used. 1 Quote Link to comment
tgaydos Posted June 2, 2018 Author Report Share Posted June 2, 2018 Hopefully Degaux or distributor guy or Hose stup will chime in. At this time iam only running low pressure carbed. I was not sure if you were going to carb your KA. Farmer Carbbed his KA. that would be interesting, but my reasons for ka is one the truck didn't have a motor to begin with and two to get away from carb. :) 1 Quote Link to comment
Stoffregen Motorsports Posted June 2, 2018 Report Share Posted June 2, 2018 Can you run the stock KA24DE pump? Do you have the DE fuel tank? If so, cut out the pump module and mounting flange, weld it into the tank you're going to use, and have the pump, sender, EVAP, etc that was intended for the motor. If not, then use a Tanks INC PA series module. In tank pumps are always best. They run quieter, cooler and last longer. 1 Quote Link to comment
bottomwatcher Posted June 2, 2018 Report Share Posted June 2, 2018 I am running the walboro on my ka24e and it works fine but sure is loud. I am half ass keeping an eye out for a hardbody tank and pump. The in tank would be the way to go. 1 Quote Link to comment
tgaydos Posted June 3, 2018 Author Report Share Posted June 3, 2018 i'm not real worried about it being loud, just need something to get this pig running. 1 Quote Link to comment
tgaydos Posted June 3, 2018 Author Report Share Posted June 3, 2018 i guess i was asking more specifically what psi fuel pump is needed/recommended. 1 Quote Link to comment
bottomwatcher Posted June 4, 2018 Report Share Posted June 4, 2018 There is or should be a regulater on the return line. I am running the walboro 255 works fine, need the check the authenticity of the pump. Apperrently there are a lot of Chinese knock offs put there. I purchased mine from a seller that advertised his were not chinese, seems. Ok. 1 Quote Link to comment
tgaydos Posted June 4, 2018 Author Report Share Posted June 4, 2018 Thank you I had planned on running a regulator. I found a rear plate z guy is going to bring one to canby with him. 1 Quote Link to comment
tgaydos Posted June 4, 2018 Author Report Share Posted June 4, 2018 A guy not z guy 1 Quote Link to comment
tgaydos Posted June 10, 2018 Author Report Share Posted June 10, 2018 Quick little update. Got a new grill. 1 Quote Link to comment
tgaydos Posted July 25, 2018 Author Report Share Posted July 25, 2018 quick update thus far, not much has been done since the grill at canby but i did get a fuel rail for my single cam ka waiting on the mail to get here with it. also got a driveline going to pick up today (7/25/2018) in oregon city. super stoked to keep this project moving forward. next up will be the can am wiring box, radiator, fuel system, clutch/flywheel kit, i'm sure there's more that i'm missing but we'll cross that bridge when i get there. 2 Quote Link to comment
tgaydos Posted September 26, 2018 Author Report Share Posted September 26, 2018 does anyone know where i could find some 720 motor mounts for a 2wd from 1985? i need the truck side mounts and am having a hell of a time finding any. 1 Quote Link to comment
captain720 Posted September 26, 2018 Report Share Posted September 26, 2018 Do you need the part that's welded to the frame? Mounting the Z24 or single cam ka 1 Quote Link to comment
tgaydos Posted October 4, 2018 Author Report Share Posted October 4, 2018 got the mounts and the motor is in, mostly wired up on the engine side now to figure out the interior wiring, and plumbing for fuel and cooling, transmission and a few other odds and ends hopefully it'll be driving in a couple months. 2 Quote Link to comment
tgaydos Posted October 4, 2018 Author Report Share Posted October 4, 2018 even with the write up by icehouse i am having a difficult time understanding the wiring on the ecu side of things. it seems the more i read it the more confused i get. 1 Quote Link to comment
bottomwatcher Posted October 4, 2018 Report Share Posted October 4, 2018 It's painfully slow but deal with only one wire at a time. All the different color codes gets confusing. Beer is not your friend during this stage of the swap. Bolting the engine in is the easiest part of the swap. Stick with it. Good luck. 2 Quote Link to comment
tgaydos Posted October 5, 2018 Author Report Share Posted October 5, 2018 bolting it in really is the easy part which i figured it would be, going to give wiring a break for a bit and deal with the fuel plumbing as my next task. Hopefully by then it'll start making more sense to me. 1 Quote Link to comment
tgaydos Posted November 3, 2018 Author Report Share Posted November 3, 2018 got the transmission almost ready to go in, last few things are fuel lines, wiring, cluster and radiator. cluster aside i should have it running and driving very very soon. It's been a long time coming and i can't wait. Quote Link to comment
Charlie69 Posted November 4, 2018 Report Share Posted November 4, 2018 On 9/26/2018 at 2:10 PM, captain720 said: Do you need the part that's welded to the frame? Mounting the Z24 or single cam ka captain720 the engine and trans you purchased from me is a 1985 2wd King Cab carbed Z24 5 speed. Quote Link to comment
tgaydos Posted November 8, 2018 Author Report Share Posted November 8, 2018 got the transmission mostly in today, I don't think it's lined up properly however as there's still about a half inch gap all the way around. I figured I'd give it a break for awhile as I was getting tired and frustrated and didn't want to drop the trans on myself. Quote Link to comment
bottomwatcher Posted November 9, 2018 Report Share Posted November 9, 2018 some folks put the motor and trans in as a unit, makes bolting the trans in easier. Although I have never done this myself. What I did do that I think made my ka swap a little easier was cut the flange off a trans to mount a starter and a quick wood cradle so I could start the engine out of the truck. This allowed me to kind of sprawl the engine harness and allowed full access around the engine. Handy when I realized when installing the oil pump I was 180 out. I took my time working out the bugs and I knew I had a running engine before install. Just an idea and good luck. Quote Link to comment
