Farmer Posted August 8, 2017 Report Share Posted August 8, 2017 One week away, and I dont see any post about parts. I know it cant be a swap meet, but.... I can bring up these parts if any one is interested for the right price. J13 Block refurbished, installed crank and cam. Been sitting for a while ( late 80's) probably needs re lubed and rechecked J13 block Refurbish, cranks installed. needs re lube/checked sitting since late 80's L16 block with installed crank and pistons. Needs relubed and checked 4 speed transmission. L16. According to Mike And a bunch of j13 engine rebuild parts. Most bought in the 80's Direct from Japan 2 Quote Link to comment
bananahamuck Posted August 9, 2017 Report Share Posted August 9, 2017 Either of the J13s have new rear seal installed ? 1 Quote Link to comment
Farmer Posted August 10, 2017 Author Report Share Posted August 10, 2017 Either of the J13s have new rear seal installed ? Cant physically see them but If they have changed out all the bearings and cam bearing and such, I cant see them not doing it. Also I am able to turn cranks by hand but I'd still check them it out 2 Quote Link to comment
Farmer Posted August 10, 2017 Author Report Share Posted August 10, 2017 Also have other j13 cranks and cams 1 Quote Link to comment
datzenmike Posted August 10, 2017 Report Share Posted August 10, 2017 It's from a '70-'72 521 with L16 engine. Know why? The J series driveshaft has a slip in spline. The 521 L16 transmission had a bolt in spline with flange. If you look at the top you can just see the flange 3 Quote Link to comment
nl320what Posted August 10, 2017 Report Share Posted August 10, 2017 Hey Farmer, what would you want for the J13 lot? Id like to barter for it instead of cash but will consider what you would want to take it off your hands. 1 Quote Link to comment
Farmer Posted August 11, 2017 Author Report Share Posted August 11, 2017 got 2 cast #210 cylinder heads also. 1 Quote Link to comment
Morrisun Posted August 12, 2017 Report Share Posted August 12, 2017 Spoke to another Datsun enthusiast lat night, he is bringing 620 parts and wheels, at least the ones he can fit into his Toyota pickup- he's towing his car to the event. I am bringing 4 on 4.5(114.3) 13" and 14" wheels plus Datsun 1200 coupe tail light GASKET kits and some other 1200 parts. Should be nice cool day. The White Salmon coupe is rumored to make an appearance! 1 Quote Link to comment
