Datsun 620 door panels - standard vs deluxe
carterb
I have 79 Deluxe KC doors on my 78 620.  The door panels go all the way up to the window.  I'd like to swap them for the shorter standard door panels.  Is there any difference in the doors themselves that would prevent this swap?
Thanks for the info.
--carter
  • Replies 5
No difference. However, if I remember correctly the early doors with the metal strip that screws to the top: they don't have receiver holes where the strip goes. So in that case you would have to drill the holes. I kind of remember having to drill some holes...In your case you should be fine.
--carter
You mean right up to the glass???? Does it include the inner squeegee?
Early had a horizontal clip that ran along the top to keep them flat. Later ones had 'snaps' across the tops. Both of these stop short of the window glass and left metal showing where your arm would rest on it..
