Caliper bolt spacing?
Anyone know why my caliper bolt spacing is off by 8mm compared to the new ones that just came from RockAuto?
New calipers arrived in the mail
Did I order the wrong ones?
Bolt spacing is 8 millimeters too short and it does not Center itself on the rotor
Attach file:
jpg.gif  20170502_160015-600x800.jpg (124.67 KB)
jpg.gif  20170502_160210-600x800.jpg (135.16 KB)
jpg.gif  13419_5908e8a81d2ee.jpg (46.90 KB)
  • Replies 13
Arggggghhhhhhh
So frusterating. Apparently some 120ys had a caliper bracket and some did not. Impossible to tell if this is even a 120y strut or B310 or 1200
I have old cruddy brakes that came with the struts but they dont even seem to fit right either.
It is from Datsun Sunny 1976-1978
54303-H7405 STRUT, LH
AMPCO was a Datsun factory supplier
B210 used many different strut part numbers, but they look mostly identical. Those that start with H10/H50 have the small stub axle/large bearings, and those that start with H74 have the large stub axle/small bearings
What was the US version of the 1976 Sunny?
They are NOT B310. I can promise you that.
In the US, only the 1200 used bolts and nuts to hold it onto the steering arm. Everything else used threaded holes in the strut base and just bolts (no nuts).
Also, the B310 used the larger lower bolt spacing, a la 510/610/710/A10/280ZX.
Good info DF.
Looks like im up shits creek.
1. Get my aussie brakes stripped and rebuilt. Make them work somehow so they center on the rotor.
2. Scrap my new suspension / steering. Buy a swap like possibly 280zx struts and new brakes.
