SaltyChicken456 Posted April 2, 2017 Report Share Posted April 2, 2017 Alright everyone, I've got a 629 with an L20b with probably a lot of miles. I'm not real sure how many it's got on it to be honest, I picked the truck up from some guy who's been driving it like this for about 5 years. But it sounds great and runs great, makes good oil pressure and stays cool and all that. But once it's up to temp, I get a valve tick. Reminds me of my buddy's old Mazda pick up that had one about just as loud. So my question is how would you solve it? Adjust valves? Not change anything with it? Resort to horrible Oil additives? I'm not real confident I can adjust the valves properly myself. Quote Link to comment
datzenmike Posted April 2, 2017 Report Share Posted April 2, 2017 Never use additives. Check the valve lash. The loosest one it the one that tics when warmed up. Warm engine thoroughly and set to TDC. This will allow you to check / set... intake and exhaust on #1 intake on #2 exhaust on #3 Turn engine ONE full turn up to TDC now you can set... exhaust on #2 intake on #3 intake and exhaust on #4 ... done. Doing it this way is faster than bumping the engine constantly and it's done before the engine gets cold. Intake...... 0.010" exhaust... 0.012" Quote Link to comment
SaltyChicken456 Posted April 2, 2017 Author Report Share Posted April 2, 2017 So when you say one full turn on the engine, do you mean a 360* turn on the crank pulley and then continue? Quote Link to comment
SaltyChicken456 Posted April 2, 2017 Author Report Share Posted April 2, 2017 Well that doesn't sound too bad. I have feeler gauges. I think I'll give it a shot. Quote Link to comment
Crashtd420 Posted April 2, 2017 Report Share Posted April 2, 2017 Take a good look while your in there, Ive read and seen slight damage to the retainers and lash pads causing the lash pad to be a bit loose too... it should be fairly obvious if something is bad, but hopefully it's just an adjustment needed... Quote Link to comment
russaroll Posted April 2, 2017 Report Share Posted April 2, 2017 better to hear them than smell them Quote Link to comment
SaltyChicken456 Posted April 2, 2017 Author Report Share Posted April 2, 2017 All the valves were WAY too tight, got them all adjusted properly and also found this gem in there on cyl 4 https://imgur.com/gallery/XofAB Quote Link to comment
SaltyChicken456 Posted April 2, 2017 Author Report Share Posted April 2, 2017 And the tick is still there. Just as bad. Quote Link to comment
Crashtd420 Posted April 2, 2017 Report Share Posted April 2, 2017 Well i would call that fairly obvious... I don't think you can adjust that out.... even if you realign and reset... The ticking has to be related to that.... have you taken the valve cover off and see if it moved again?.... I'd think that lash pad should be replaced... you can also see if it's loose in the reatainer.... How did the rest look?... someone might be able to help with a spare lash pad... I know I have some extra I'll never use.. Pull it out and see what size it is... Quote Link to comment
SaltyChicken456 Posted April 2, 2017 Author Report Share Posted April 2, 2017 Re seated that rocker and adjusted them all hot. Still ticking. I agree it had to be related to that rocker though. Quote Link to comment
Crashtd420 Posted April 2, 2017 Report Share Posted April 2, 2017 I had ones that were loose in the retainer, It could actually rock side to side slightly.... If everything else looked good I'd try replacing that lash pad and continue from there... Quote Link to comment
banzai510(hainz) Posted April 2, 2017 Report Share Posted April 2, 2017 looking closer the cam looks like a GOUGE in there. I think the lash pad is fine. just line it back up which Im sure you did already. Just me here file that gouge out then rerun in and hope it wears in or find a junk head and try another rocker arm . Quote Link to comment
thisismatt Posted April 2, 2017 Report Share Posted April 2, 2017 Why does it look like someone spray painted the cam towers? Head looks diiirty Quote Link to comment
datzenmike Posted April 2, 2017 Report Share Posted April 2, 2017 Learn to post the picture. Excessive lash can allow the rocker to jump off the lash pad.Take rocker and lash pad out and examine. If worn or gouged then replace otherwise put it back on and set clearance You should be able to very slightly wiggle the rocker even with the correct valve lash. I mean there is 0.010" of play. That engine needs more regular oil changes. Use Shell Rotella T or Chevron Delo 400 15w40. It's a light diesel oil with safe levels of ZDDP in the formula. Diesel oils are also more detergent and will clean that engine up. Always change filter when changing oil. Don't use fram. Use NAPA gold or wix. Quote Link to comment
