Ricky1981 Posted April 18, 2016 Author Report Share Posted April 18, 2016 If your motor was originally fuel injected, then you need a carb style z24 dizzy. The FI dizzy is a crank position sensor. Thanks for ur answer. What years am I looking at and do i have to get diffrent coils or will the ones i have from the d21 work? Quote Link to comment
Ricky1981 Posted April 18, 2016 Author Report Share Posted April 18, 2016 so cleannnn Quote Link to comment
Ricky1981 Posted April 18, 2016 Author Report Share Posted April 18, 2016 so cleannnn Thanks Quote Link to comment
Lockleaf Posted April 19, 2016 Report Share Posted April 19, 2016 83 - 85 trucks distributors will work for sure. There may be other pieces necessary for the swap though. You may need the pedestal that the distributor bolts to. You may also need the shaft between the oil pump and distributor. I am fairly confident the coils will work fine. Other 8 plug Z dizzys will likely work as well. Quote Link to comment
datzenmike Posted April 20, 2016 Report Share Posted April 20, 2016 Definitely need the drive spindle. The CAS is splined. Here's mine... The spline makes the CAS extremely accurate with zero timing wander from slop and looseness of the L and Z series 'screwdriver blade' drive distributors. . 1 Quote Link to comment
Ricky1981 Posted April 21, 2016 Author Report Share Posted April 21, 2016 https://goo.gl/photos/fLYVmiqip64tyqJX7 Quote Link to comment
Ricky1981 Posted April 21, 2016 Author Report Share Posted April 21, 2016 I hit the junk yard this morning and got super lucky came across a 1983 720 chilling waiting for me jaja , came home and put everything back together ,and started it 1st try so ☺ thanks guys Quote Link to comment
Ricky1981 Posted April 21, 2016 Author Report Share Posted April 21, 2016 https://goo.gl/photos/yG6AvPsav78rrxWt5 Quote Link to comment
flatcat19 Posted April 21, 2016 Report Share Posted April 21, 2016 Should have grabbed the pedestal too-just to be safe. Quote Link to comment
Ricky1981 Posted April 21, 2016 Author Report Share Posted April 21, 2016 Should have grabbed the pedestal too-just to be safe. Yeah I got it also. Quote Link to comment
Lockleaf Posted April 21, 2016 Report Share Posted April 21, 2016 Nicely done. Did you need the pedestal, or just dizzy and shaft? Quote Link to comment
Ricky1981 Posted April 21, 2016 Author Report Share Posted April 21, 2016 Nicely done. Did you need the pedestal, or just dizzy and shaft? Thanks for ur info bro. Yes I had to get the pedestal , the shaft and the dizzy I also got both coils just to be sure. Quote Link to comment
