Kytoaster Posted March 10, 2016 Report Share Posted March 10, 2016 Hey all, well it's finally starting to warm up here in KY, so it's time to the winter/snow tires off of my 74 620.The only problem is, the wheels and tires I have to put on are going to need spacers, and I'm not sure if 1/4" spacers will need extended lugs or not? Quote Link to comment
datzenmike Posted March 10, 2016 Report Share Posted March 10, 2016 Put one on and check the clearance. Turn the steering wheel lock to lock also to see if it hits the body anywhere. In some cases a spacer will make rub worse. If you mean something like a stack of washers... don't. You need a full plate with 4 holes and probably longer studs to replace the now 1/4" shorter ones. The rim needs to be fully supported from behind and not up on 'pillars'. In addition the lug nuts need FULL thread coverage for proper tightening and support. I'm sure you wouldn't do the former but it needs saying. Quote Link to comment
banzai510(hainz) Posted March 10, 2016 Report Share Posted March 10, 2016 1/4 inch might not need longer studs. I ran some 1/4 inch spacers and I was fine. Quote Link to comment
Kytoaster Posted March 10, 2016 Author Report Share Posted March 10, 2016 Put one on and check the clearance. Turn the steering wheel lock to lock also to see if it hits the body anywhere. In some cases a spacer will make rub worse. If you mean something like a stack of washers... don't. You need a full plate with 4 holes and probably longer studs to replace the now 1/4" shorter ones. The rim needs to be fully supported from behind and not up on 'pillars'. In addition the lug nuts need FULL thread coverage for proper tightening and support. I'm sure you wouldn't do the former but it needs saying. No no, definitely a set of real spacers. No stacked washers for me. I may be a "shadetree mechanic"...but....dang...not that shady. Quote Link to comment
Rjawm Posted March 10, 2016 Report Share Posted March 10, 2016 A good rule of thumb is to have a minimum of thread depth engaged that matches the studs width. Any less would require extended studs to ensure proper and safe thread engagement. For example, on an M12 stud it should have a minimum of 12mm of thread engaged by the lug nut itself. I forgot to mention, if they can fit on your choice of wheel, ET lug nuts are an option as well if you are really close to clearing the minimum. Within a couple millimeters usually. The threaded portion of the lug is extended into the wheel seat to gain more thread engagement. Quote Link to comment
distributorguy Posted March 11, 2016 Report Share Posted March 11, 2016 Be careful with those lug nuts. At 55 ft lbs (significantly more with alloy wheels), there is very little strength between the threads at the thin section of those nuts. Material thickness is marginal, plus the threads are cut not rolled, so they are prone to crack under stress. Even if they were made from tool steel and properly heat treated (think $30-40 each) they wouldn't be as strong as you would hope. When I found wheel studs for my race truck (2 1/2") I remember there being one other option just a bit longer than stock. Quote Link to comment
Kytoaster Posted March 14, 2016 Author Report Share Posted March 14, 2016 Well, with the 1/4" spacers, the lugnuts I have don't even reach the lugs through the wheels/spacers. Took the spacers back and am ordering some 1" spacers/adapters, as the rear tires were barely rubbing on the frame. Quote Link to comment
UnderControl Posted March 15, 2016 Report Share Posted March 15, 2016 I ended up getting 60mm S13 studs. Keeps the same thread pitch and gives enough stud with to bite on with 1/4" spacers on chevy style rallies with acorn nuts. Quote Link to comment
