Distributor Module 620
ERBooks
  • Replies 11
They replace them with inexpensive  GM HEI modules
They are in almost every middle 70s- 90s GM product in the junkyard
Link to explain ,, clickity -clickity
http://community.ratsun.net/topic/17444-electronic-ignitions-for-l-motors-4-cyl/
Looking for a source for my '78 620 distributor electronic module which failed. Suggestions? Thanks
Are you talking about the control module on the passenger side kick panel area?
If so, I have one. $30 shipped. Let me know. Please send me a message and we can go from there.
Mike, Where did you get the photo of the 79/80 distributor?  Just wondering, as it looks like one I rebuilt.
The HEI modules are commonly wired as shown in the diagram above, but normally you also want to add a condenser from a points distributor to the power input wire to help control voltage variations and help absorb plug wire noise issues (not radio noise interference, but rather noise that disrupts the ignition signal.)  Module grounding is 100% critical, so make sure its perfectly grounded to the chassis or it won't work at all.  Grounding may be why your current module doesn't work.
First, these modules hardly ever go bad so make sure it's the module first. What's wrong? no spark?
1/ Is there 12 volts to the coil + side?? when cranking and when key in the ON position?
2/ Is there 12 volts to the B terminal on the module??? when cranking and when key in the ON position?
You HAVE TO HAVE 1/ and 2/ above.
3/ Install a separate ground on the distributor like the one below. Distributor MUST have good ground
4/ Is the coil good?
You have the matchbox module with the red and green wires inside..
Just use the diagram below and wire up an HEI module in it's place. Wrecking yards are full of them and they are a perfect fit into your back pocket, or $20 at NAPA
Lots of reasons for cutting out when warm.
Idle jet plugged.Not noticeable when choke is on.
Idle cut solenoid not connected. No idle fuel.
Coil (specially if after market) may over heat and quit.
Next time it quits pull plug wire off and see if there is spark. Don't assume.
If you have a tester, measure the resistance of your plug wires.  They should be under 3000 Ohms.  Over 10,000 Ohms will overheat the coil and it will stall out.
So will a bad module ground/distributor ground/engine ground.  You can ground the module directly to the battery as a test if you like.  Remove it and clean the back, and remove the piece behind it and clean that too.
