Putting 1/2 Chevy axels under my 81 Datsun
Lakec423
I have the axels with the leaf springs I know I'm gonna have to move the saddle for the leafs and figure out breaking but should I run a 4x4 Chevy steering box also what should I do about drive shafts ? It's a passenger side drop so that's in my favor the axels are Chevy 10 bolt with 3,73s.
  • Replies 41
It's a 4x4 you need more gear not less. A 3.73 will barely turn the tires. Is this from an S10 chev because aren't the entire wheels going to be outside the fenders???
129_1004_36+top_truck_challenge_2010+197
Go with early 80s Toyota. Lots of support for them and the fit. Tons of gear options and LSD.
Yeahh tires are gonna be out there that's not a prob and in 4 low it should pull fine running down the road in not gonna take it much over 55 Ill let you guys know how it turn out I just don't know what I'm gonna do about drive shafts I was gonna go with a Chevy steering box but I'll just have to learn as I go
Not sure what your question about drive shafts is. They have to be customized no matter what, so what is the real question? Diameter, material, etc?
Passenger side drop on a 720 doesn't really matter. The tcase drops dead center, so it can go to either side with equal efficacy. 3.73 is a highway gear for trucks. It's going to take lots of rpms to get them turning well, so when shifting on the trail, you will have to stay in high rpm. You say you won't go above 55, but those gears are meant for highway speeds. Stock you are likely running 4.11, maybe 3.9, so you're already reducing low end useability from stock. That's why Mike recommended against them. This won't help you create a trail truck. It's the recipe for a wide 100 mph cruising truck.
For steering, I recommend you do a lot of reading of other 720 SAS builds and see how they resolved issues. Poormans720 is a good place to start. Google 720 sas or his screen name and read up.
Is there such a thing as a chevy 4x4 without power steering???? If there is you'll wish you had it with big tires. Helps if you have a PS pump on your '81. The 4.3 should have it.
Are there laws in Florida regarding exposed tires without fender or flair coverings?? Most places won't allow it on the road.
The '81 4x4 ran 4.375 gears. The stock tire size is about 27". Going to 33s will seem like 3.57 (worse than the 3.73) and be sluggish as hell on acceleration. Your lowest crawl speed will also go up by 22%. To maintain the same crawl speed on 33" tires you would need a 5.30 differential swap
If you top out at 70 in 4th that would be around 3,800 RPM I would guess. This is where the air resistance equals the power made by the engine to push through it. A five speed is an over drive gear that lowers the PRMs of the engine to save gas at cruising speed. Lower RPMs will make less power at 70 and you will go slower.
Here's a sobering thought about air resistance. It takes 4 times the power at 40 MPH to go 80 MPH. Doubling the speed takes 4 times the power.
I'm guessing you are trying to throw together a truck with full width axles on the cheap, and you think you can do it for labor only. Have you ever built an offroad truck before? Are you good at fab? What kind of welder do you have? Do you want it to be nice when you're done? Roadworthy?
There's a lot more to building a cool truck than stuffing full width axles under it. If driveshafts have you stumped, good luck on the rest of the build.
If you have Chevy axles and a Nissan t-case, a good place to start is with a pair of Nissan driveshafts and a pair of Chevy driveshafts. Cut the ends off and piece them together. If don't you want them to vibrate, you're going to want CV joints at the t-case. If you need lots of slip, you can find long slip parts online at places like Tom Woods, High Angle Driveline, Trail Gear or even at your local driveline shop.
A pair of custom built shafts with new parts can cost you $300 to $400 each. If you bring the parts, they can be done for the price of tubing and labor, roughly $200.
In that case, I say go for it. In your shoes, I would plan on gears being my first post build upgrade. I get the whole budget thing, so just build it the best you can now, and look at what upgrades in the future will be best, both in budget and in usefulness.
Start your build thread, let's see this happen.
