thisismatt Posted August 25, 2015 Report Share Posted August 25, 2015 Why take it in for exhaust if it doesn't run? :P 1 Quote Link to comment
DatMo Posted August 25, 2015 Author Report Share Posted August 25, 2015 Focus on your clutch, and your tranny... problem solv i turned the crank to put the shaft on while splines were in so doesnt that mean tranny works? it's in neutral, why does clutch matter? Quote Link to comment
DatMo Posted August 25, 2015 Author Report Share Posted August 25, 2015 Why take it in for exhaust if it doesn't run? :P it did run and i was towing it. lol fucking datsun Quote Link to comment
Draker Posted August 25, 2015 Report Share Posted August 25, 2015 If its in neutral, why is the output shaft moving? 1 Quote Link to comment
Draker Posted August 25, 2015 Report Share Posted August 25, 2015 I don't understand the issue I guess. Can you not shift into gear? Can you shift into gear but the car doesn't move? Quote Link to comment
DatMo Posted August 25, 2015 Author Report Share Posted August 25, 2015 If its in neutral, why is the output shaft moving? its not. nothing is movie. thats the problem even in gear, nothing. maybe the splines need more grease? I'm not sure at all Quote Link to comment
thisismatt Posted August 25, 2015 Report Share Posted August 25, 2015 You sure it's out of gear? Ya sure? Quote Link to comment
flatcat19 Posted August 25, 2015 Report Share Posted August 25, 2015 I'm willing to bet this is something retardly retarded. 3 Quote Link to comment
thisismatt Posted August 25, 2015 Report Share Posted August 25, 2015 I'm willing to bet this is something retardly retarded. Can't be as bad as page 4 on the 521 electric fuel pump thread... 1 Quote Link to comment
flatcat19 Posted August 25, 2015 Report Share Posted August 25, 2015 So, car is in the air...both rear wheels move? Both front wheels move? Car is not in gear? Quote Link to comment
flatcat19 Posted August 25, 2015 Report Share Posted August 25, 2015 Can't be as bad as page 4 on the 521 electric fuel pump thread... I saw that one going downhill. Left well before that. Quote Link to comment
DatMo Posted August 25, 2015 Author Report Share Posted August 25, 2015 So, car is in the air...both rear wheels move? Both front wheels move? Car is not in gear? car is not in gear. its in neutral. wheels wont move when its on the ground. i have no fucking clue. no gear, and brake off Quote Link to comment
thisismatt Posted August 25, 2015 Report Share Posted August 25, 2015 I saw that one going downhill. Left well before that. You gotta check it out, just scroll down to the 2nd picture Quote Link to comment
thisismatt Posted August 25, 2015 Report Share Posted August 25, 2015 car is not in gear. its in neutral. wheels wont move when its on the ground. i have no fucking clue. no gear, and brake off And how are you trying to move the car? 2 Quote Link to comment
flatcat19 Posted August 25, 2015 Report Share Posted August 25, 2015 Have you put car on jacks and spun the wheels? Quote Link to comment
Draker Posted August 25, 2015 Report Share Posted August 25, 2015 Then why are you moving the crank to line up the spines on the driveline? What splines are you aligning? Did you install a clutch disc? Are you sure you are shifting into gear? Can be tough if tranny is dry or worn. Quote Link to comment
Draker Posted August 25, 2015 Report Share Posted August 25, 2015 Or if say..... your clutch isn't bled. Quote Link to comment
flatcat19 Posted August 25, 2015 Report Share Posted August 25, 2015 Did you put clutch in backwards? Quote Link to comment
Scgreen620 Posted August 25, 2015 Report Share Posted August 25, 2015 Try connectin the Drive shaft into transmission... Add oil in tranny, try again Quote Link to comment
DatMo Posted August 25, 2015 Author Report Share Posted August 25, 2015 Did you put clutch in backwards? no I just put up all the wheels theyre fucking spinning. if it's in neutral, the driveshaft shouldn't spin i thought? all the fucking wheels are turning. the tranny is dry however it just recently flushed it and i need gl4 but i dont see how that stops it from moving an inch. Quote Link to comment
DatMo Posted August 25, 2015 Author Report Share Posted August 25, 2015 Try connectin the Drive shaft into transmission... Add oil in tranny, try againim im going to try this again tomorrow. i have no choice Quote Link to comment
dat521gatherer Posted August 25, 2015 Report Share Posted August 25, 2015 Can't be as bad as page 4 on the 521 electric fuel pump thread... I was going to say something similar. I laughed my ass off when I saw that pic. For two days. Quote Link to comment
thisismatt Posted August 25, 2015 Report Share Posted August 25, 2015 The driveshaft will always move when the wheels are both turning in the same direction Quote Link to comment
dat521gatherer Posted August 25, 2015 Report Share Posted August 25, 2015 You need to remove the rear tire chock. 3 Quote Link to comment
DatMo Posted August 25, 2015 Author Report Share Posted August 25, 2015 The driveshaft will always move when the wheels are both turning in the same direction oh then id be incorrect about the neutral thing. well tomorrow ill try to rebleed everything and put more fluids in and see what happens. i guess no exhaust shop Quote Link to comment
