scooter Posted May 25, 2015 Report Share Posted May 25, 2015 Has anyone tried running a 225mm ka-e flywheel in place of a normal l series 225mm flywheel? Is it safe to assume the crank flange is the same? What about ring gear size? The reason behind this is i found out ACT has a lightened flywheel that is sfi approved, which is kinda safer than the turned down one i have now. Its for ka-e, and de in 225 mm. Any info would be awesome. Quote Link to comment
datzenmike Posted May 25, 2015 Report Share Posted May 25, 2015 I think it will fit. The KA and the Z24i used the same transmission. Starter ring are in the same place and size, 6 mounting bolts. I have a KA24E crank and a half dozen L and Z series wheels. The crank has a small brass dowel to line up on the KA wheel but easy enough to knock it off and see if the L 225mm will fit. I'm sure it does. Quote Link to comment
Jester Posted May 25, 2015 Report Share Posted May 25, 2015 Interesting. Let us know what you find out Mike. Quote Link to comment
MicroMachinery Posted May 25, 2015 Report Share Posted May 25, 2015 He can't find out anything. There's nothing Mike doesn't know about trannies. Quote Link to comment
Stoffregen Motorsports Posted May 25, 2015 Report Share Posted May 25, 2015 I'm pretty sure the register on the back of the crank is totally different. Quote Link to comment
Farmer Joe Posted May 25, 2015 Report Share Posted May 25, 2015 should work. the flywheel on my KA right now is from a z24. this same flywheel has been on my L20b, another z24, the KAe and now my DE. id say go for it. Quote Link to comment
datzenmike Posted May 25, 2015 Report Share Posted May 25, 2015 I don't have a truck KA crank but the S13 has a small dowel pin that gets in the way. I'll try an L flywheel tonight, Quote Link to comment
scooter Posted May 26, 2015 Author Report Share Posted May 26, 2015 I think that'll work. The goal here is to put a 225mm ka flywheel on an l/z crank. Usually that pin stays with the crankshaft on every other one ive worked on, or theres an offset bolt. Farmer joe has pretty much confirmed what i needed to know. This head scratcher started because i noticed the act 225mm ka kit is the same part number as the 225mm l series one, but they dont list a flywheel for the l series, but they do for ka's, even though they use the same clutch/pressure plate for both. Id be happier with a chromoly sfi rated flywheel in there, dont have to worry about the stock lightened flywheel comming apart and taking my ankle off, if i can make it work. And theyre 10 pounds.... Because racecar :D Quote Link to comment
datzenmike Posted May 26, 2015 Report Share Posted May 26, 2015 OK I have a 240mm wheel from a Z24... it fit no problem. I have a 225mm and it almost fits the small projection in the center of the KA wheel. The 225mm will fit the outer shoulder of the crank and this would be enough if the inner hole on the wheel was trimmed slightly. POSSIBLY Z series wheels will fit the KA but L series will not? I know L and Z series will interchange but the L and Z cranks do not have that inner projection that has to fit the hole in the L and Z wheels. I'll have another look tonight. Maybe the projection on the KA crank could be ground away??? Quote Link to comment
Stoffregen Motorsports Posted May 26, 2015 Report Share Posted May 26, 2015 Mike, did you try that on a bare crank or on a shortblock? I worry that the back of the crank on the KA does not stick out enough and that when you try to bolt up the Z (or L) flywheel, it will hit the back of the block. Maybe car and truck KA's are different. I didn't think so... Quote Link to comment
datzenmike Posted May 26, 2015 Report Share Posted May 26, 2015 Just a crank and a wheel. The blocks are definitely different but interchangable. Quote Link to comment
