jefe de jefes Posted May 24, 2015 Report Share Posted May 24, 2015 There is a 1980 310 near me and its front wheel drive. Anybody know if the engine can be used in a rear wheel drive setup? I'm thinking of using an A series engine in my 320. Quote Link to comment
MicroMachinery Posted May 24, 2015 Report Share Posted May 24, 2015 Just get an SR20 from a FWD Sentra and call it a day Quote Link to comment
datzenmike Posted May 24, 2015 Report Share Posted May 24, 2015 Yes the FWD A series engines will work in RWD cars. You will need a RWD A series transmission. Quote Link to comment
jefe de jefes Posted May 24, 2015 Author Report Share Posted May 24, 2015 Just get an SR20 from a FWD Sentra and call it a day I'm looking for an engine for my 320. A series should fit I think. Quote Link to comment
jefe de jefes Posted May 24, 2015 Author Report Share Posted May 24, 2015 Yes the FWD A series engines will work in RWD cars. You will need a RWD A series transmission. Right on. I'm going to go look at it tomorrow. Quote Link to comment
Ratwagon1600 Posted May 25, 2015 Report Share Posted May 25, 2015 Look at project binky. Nothing !!! Is impossible after that. Quote Link to comment
Jester Posted May 25, 2015 Report Share Posted May 25, 2015 Project Binky is bad ass. That was a lot of video's to watch but DAMN! Quote Link to comment
Stoffregen Motorsports Posted May 25, 2015 Report Share Posted May 25, 2015 Project Binky got nothin' on this: http://www.speedhunters.com/2014/12/the-hoonicorn-rtr-build-story/ Quote Link to comment
Stoffregen Motorsports Posted May 25, 2015 Report Share Posted May 25, 2015 There is a 1980 310 near me and its front wheel drive. Anybody know if the engine can be used in a rear wheel drive setup? I'm thinking of using an A series engine in my 320. Plenty of guys run the A-series in their 320's. I had two of them. It's not a hard swap, but there are a couple things to look out for. Alternator location: Get a motor with the alternator up high on the passenger side and the distributor towards the middle of the block. The A12's had the alternator mounted low on the driver's side and it will hit the stock 320 steering box. Oil filter: The stock A oil filter hits the 320 idler arm, but a simple fix is to use a small filter like one from a Toyota 22re. Shifter location: if you push the motor too far back, two problems occur. The shifter will run into the bench seat and the back of the trans will run into the horse-collar crossmember. Fan: An electric fan must be used in lieu of the stock A-series mechanical radiator fan. Quote Link to comment
jefe de jefes Posted May 25, 2015 Author Report Share Posted May 25, 2015 Plenty of guys run the A-series in their 320's. I had two of them. It's not a hard swap, but there are a couple things to look out for. Alternator location: Get a motor with the alternator up high on the passenger side and the distributor towards the middle of the block. The A12's had the alternator mounted low on the driver's side and it will hit the stock 320 steering box. Oil filter: The stock A oil filter hits the 320 idler arm, but a simple fix is to use a small filter like one from a Toyota 22re. Shifter location: if you push the motor too far back, two problems occur. The shifter will run into the bench seat and the back of the trans will run into the horse-collar crossmember. Fan: An electric fan must be used in lieu of the stock A-series mechanical radiator fan. Sweet, thanks for the tips! The project builds mentioned above are insane! Quote Link to comment
