djwarp Posted August 14, 2015 Author Report Share Posted August 14, 2015 So i bought the housing for 35 bucks brand new off a nissan dealer ship but when i got home i noticed it was missing a hole for the fitting that goes into the carb has any one ever threaded their own hole into it? 1 Quote Link to comment
djwarp Posted August 18, 2015 Author Report Share Posted August 18, 2015 I notice that my fuel filter had coolent what should I do ? 1 Quote Link to comment
banzai510(hainz) Posted August 18, 2015 Report Share Posted August 18, 2015 I notice that my fuel filter had coolent what should I do ? WHAT!!!!!!!!! you sure? You pour anitfreeze in your gas tank? I dont see how this happen. This over heat or running low on antifreeze as for the stat housing they made 2 types. 1 with a hole and 1 without. How about some of your orginal set up 1 Quote Link to comment
djwarp Posted August 18, 2015 Author Report Share Posted August 18, 2015 I put one without drilled and threaded a hole for the carb idk if that might be it 1 Quote Link to comment
djwarp Posted August 19, 2015 Author Report Share Posted August 19, 2015 Any thing i can do to fix this? 1 Quote Link to comment
datzenmike Posted August 19, 2015 Report Share Posted August 19, 2015 So i bought the housing for 35 bucks brand new off a nissan dealer ship but when i got home i noticed it was missing a hole for the fitting that goes into the carb has any one ever threaded their own hole into it? There is no fitting from the thermostat housing to the carb so you're explaining it incorrectly. Post a picture and explain. I notice that my fuel filter had coolent what should I do ? Again impossible to make sense of this. A picture would probably help. 1 Quote Link to comment
banzai510(hainz) Posted August 19, 2015 Report Share Posted August 19, 2015 Mike I think he means the U shaped hose from the housing to the heater line to the carb.. There was recently a microfish posted on the 2 types in another thread. Yes hard to understand him 1 Quote Link to comment
djwarp Posted August 19, 2015 Author Report Share Posted August 19, 2015 The only line going into the carb from the thermostat 2 Quote Link to comment
banzai510(hainz) Posted August 19, 2015 Report Share Posted August 19, 2015 What the Fuck!!!!!!!!!! your pumping water in to the carburator!!!!!!!!!! 4 Quote Link to comment
djwarp Posted August 19, 2015 Author Report Share Posted August 19, 2015 That's how it was before the thermostat housing broke 1 Quote Link to comment
banzai510(hainz) Posted August 19, 2015 Report Share Posted August 19, 2015 where does the fuel pump line go to??????????The Radiator. Pull the plugs and turn over and blow all the water out Carb is now full of water anti freeze. You just went Backwards!!!!!!! 1 Quote Link to comment
banzai510(hainz) Posted August 19, 2015 Report Share Posted August 19, 2015 That's how it was before the thermostat housing broke NOWAY!!!!!!!!! then this truck wasnt running That is a carburator where that hose is going too. Take a better photo of everything. PHOTO of the Fuel pump also and where the gas line goes too 1 Quote Link to comment
djwarp Posted August 19, 2015 Author Report Share Posted August 19, 2015 Fuel pump went on the top one 1 Quote Link to comment
djwarp Posted August 19, 2015 Author Report Share Posted August 19, 2015 Alright ill do it when I get home 1 Quote Link to comment
banzai510(hainz) Posted August 19, 2015 Report Share Posted August 19, 2015 show photos. Only way antifreeze is in the spark plugs like you said is what you just did. More photos 1 Quote Link to comment
djwarp Posted August 19, 2015 Author Report Share Posted August 19, 2015 Alright I'll check 1 Quote Link to comment
datzenmike Posted August 20, 2015 Report Share Posted August 20, 2015 It makes total sense now. 3 Quote Link to comment
dat521gatherer Posted August 20, 2015 Report Share Posted August 20, 2015 Oh my. 4 Quote Link to comment
Doctor510 Posted August 20, 2015 Report Share Posted August 20, 2015 OK here is what I see, you have the fuel line hooked up to the WATER by-pass fitting on the thermostat housing, it needs to be hooked up to the fuel pump! Some how I don't think your MOS in the Marines was motor pool... Might want to check where you are pumping fuel into. 1 Quote Link to comment
djwarp Posted August 20, 2015 Author Report Share Posted August 20, 2015 OK here is what I see, you have the fuel line hooked up to the WATER by-pass fitting on the thermostat housing, it needs to be hooked up to the fuel pump! Some how I don't think your MOS in the Marines was motor pool... Might want to check where you are pumping fuel into. I am a motor t operator not a mechanic but Thanks for the input I'll change that out what should I do to flush out the coolent from the carb? 1 Quote Link to comment
