DatsunHiLife Posted February 16, 2015 Report Share Posted February 16, 2015 Truck: 1977 620 extended cab Distributor: Hitachi Been ripping through my engine that was neglected for some time. Just put on a 32/36 weber, replaced the stock full pump with a electric fuel pump. My distributer is going to be taken out next as its just beat up pretty bad. I am wanting to replace the entire distributor with a Hei. I know there are lots of posts here about this but I need a heads up. I'm not looking for the cheapest way. I am not looking for just a conversion kit. I have looked at the Pertronix flame thrower, the Mallory HEI, and there is the one at Hot Spark (the HS_HIT4) which replaces the Hitachi 4-cylinder which requires the Beru Germany blue coil. Any suggestions? ohh. I will be racing this truck in the street class division here on the island of Kauai. Parts are hard to come by here. 1 Quote Link to comment
dr.feltersnatch Posted February 16, 2015 Report Share Posted February 16, 2015 Go with a "matchbox" distributor. Cost you roughly $100 and it only took me about 20 min to swap it. Sesrch the forum its well documented. 2 Quote Link to comment
DatsunHiLife Posted February 16, 2015 Author Report Share Posted February 16, 2015 Go with a "matchbox" distributor. Cost you roughly $100 and it only took me about 20 min to swap it. Sesrch the forum its well documented. thanks. has anybody used the hot spark one before or is it a POS? http://www.hot-spark.com/1-HS-HIT4-Distributor.htm 1 Quote Link to comment
datzenmike Posted February 17, 2015 Report Share Posted February 17, 2015 Chinese so they are... There are two EI (electronic ignition) distributors. The Remote igniter and the later Matchbox. The remote has a separate box usually mounted in the cab and the matchbox which has the remote box miniaturized and mounted on it's side. Your call, they work the same. The remote are found on all California '75 and up L series vehicles. In '78 ALL Nissans had them and in '79 and '80 all were matchbox style. The non California single plug head NAPS Z20 series engines for '80 has a matchbox that will also fit the L series. Rather than deal with the remote igniter box you can easily and cheaply substitute an HEI module on them. On both EI distributors, the matching coil should be used with it. Using a points coil will fry it as the matchbox is capable of drawing a much higher current through it. You can use your points coil IF you keep the ballast resistor. 4 Quote Link to comment
banzai510(hainz) Posted February 17, 2015 Report Share Posted February 17, 2015 this is simple,key is make sure the bushing isnt already worn out as they are pushing 35yrs old or older they are all good even the conversion kits key is get on olddatsuns.com in the tech section and save it and read all of it carefully. names like HOt and Flame dont mean its better than stock jap parts. Trust us my Opihi eating brother!!!!!!!!! 2 Quote Link to comment
tr8er Posted February 17, 2015 Report Share Posted February 17, 2015 Sup Hawaiian! I'm using the pertronix. Works great, but I'd never race with it. It just always feels weak for whatever reason. 3 Quote Link to comment
DatsunHiLife Posted February 17, 2015 Author Report Share Posted February 17, 2015 Raja Dat my fellow Ratsuns. Yea I won't be messing with the Chinese Hei....My neighbor ended up giving me an Pertronix Ignitor so Ill use that for the next week till I replace with a Nissan matchbook, Hopefully I can have her up and running my next Sunday. Race day Appreciate all the info from you guys. vroooommmmmm vroooommmm Gotta go tattoo and put a hurting on someone!! Cheese hee 1 Quote Link to comment
ppeters914 Posted February 17, 2015 Report Share Posted February 17, 2015 hainz said "opihi".....yum. Lucked out Saturday....Central Market actually made some damn fine ahi poki. Yo, Diane. Wat chu like? I want a Zippy's Zip Pack! .....and wash it down with old school Primo. Ron Whodaguy wouldn't lead ya astray, eh? Good times.....good times..... 2 Quote Link to comment
banzai510(hainz) Posted February 17, 2015 Report Share Posted February 17, 2015 pertronix will work if the ring above the point lobe is ground flush so the magnet ring fits on the point lobe. what you can do is superglue the green tape edge so it dont peel. just use the stock coil and ballast. Youll hook up the red wire to the +side of the ballast resisitor. Yes there. that should be a blk /white wire feeds the ballast . This is the usual datsun standard. then Blk wire of Pertronix to - side coil. do you really need a Matchbox? I dont think so but if it makes you feel better. key is if dist is worn or not also. also if you get a matchbox there were 2 distributor pedastals made. one is the common onw which will fit the point one also then there is anbother offset one . Hopefully you get the whole unit with pedastal and timming plate. In part store tyep dont sell those with it. 2 Quote Link to comment
DatsunHiLife Posted February 20, 2015 Author Report Share Posted February 20, 2015 Brah!! this is why Ratsun.net rules. Much mahalos for the info L Motor God. hainz said "opihi".....yum. Lucked out Saturday....Central Market actually made some damn fine ahi poki. Yo, Diane. Wat chu like? I want a Zippy's Zip Pack! .....and wash it down with old school Primo. Ron Whodaguy wouldn't lead ya astray, eh? Good times.....good times..... Lol. I never taste Poke outside of Hawaii. I guess if you get the Mana in the recipe then its all Pono!!! 1 Quote Link to comment
tr8er Posted February 21, 2015 Report Share Posted February 21, 2015 But Primo is not pono. It's just not. It's not even green 1 Quote Link to comment
