ITzDarcy Posted January 9, 2015 Report Share Posted January 9, 2015 I have been working hard renovating a 17 ft 1960s baravan - caravanand working hard at work and slowly working on my ute.So i got all the internals put in today and also have a new weber 32/36, power steering and a/c all ready to bolt on. Still taking my time on this build as i have 3 months left till i need it ready.Its finaly coming together. The biggest unknown problem i have is what else to buy for my ignition retard system.I have only this part at the moment.http://www.jegs.com/i/MSD-Ignition/121/8762/10002/-1Anyone else used this system before?Will try my best to update and ask questions. 1 Quote Link to comment
]2eDeYe Posted January 9, 2015 Report Share Posted January 9, 2015 Good looking motor. Any pics of the Baravan Caravan? :D Any reason not to run the stock ignition system? 1 Quote Link to comment
Stoffregen Motorsports Posted January 10, 2015 Report Share Posted January 10, 2015 The MSD boost retart system is used on turbo motors, generally speaking. I noticed you have a 32/36 so you're obviously not running a turbo...right? 1 Quote Link to comment
ITzDarcy Posted January 10, 2015 Author Report Share Posted January 10, 2015 i cant see the images you guys posted all i see is the file name.2 inside pictures when i received it. Glady i got this beauty for free from my boss. he has it in storage for 35 years +What my d21 looks like atm 1 Quote Link to comment
ITzDarcy Posted January 10, 2015 Author Report Share Posted January 10, 2015 The MSD boost retart system is used on turbo motors, generally speaking. I noticed you have a 32/36 so you're obviously not running a turbo...right? This is a blow through turbo build, well thats what i aspire it to be. The weber i have will have to be modified i'm betting, but it has already been jetted to run extra rich at the moment. Good looking motor. Any pics of the Baravan Caravan? :D Any reason not to run the stock ignition system? Thanks, alot of love was put into it. this car won't wont be tested in anyway to its limits but i would like to run in daily on 8psi. Quote Link to comment
datzenmike Posted January 11, 2015 Report Share Posted January 11, 2015 Car makers have been running 5-8 PSI on stock internals for ever. Look at the Chrysler 2.2 and the Ford 2.3 engines. Maybe a better head gasket but the L and Z series have huge main and rod bearings and can take it. The pistons are the limiting factor. Hyper-eutectic are about 17% silicon (basically 17% glass) and are brittle. You can buzz briefly to 10 PSI but would not run them there. Perhaps jet the secondary super rich? It's only in at 3/4s throttle and could be used only during boost. Quote Link to comment
620Turbo4X4 Posted January 20, 2015 Report Share Posted January 20, 2015 I have been working hard renovating a 17 ft 1960s baravan - caravan and working hard at work and slowly working on my ute. So i got all the internals put in today and also have a new weber 32/36, power steering and a/c all ready to bolt on. Still taking my time on this build as i have 3 months left till i need it ready. Its finaly coming together. The biggest unknown problem i have is what else to buy for my ignition retard system. I have only this part at the moment. http://www.jegs.com/i/MSD-Ignition/121/8762/10002/-1 Anyone else used this system before? Will try my best to update and ask questions. I used the MSD boost timing master on a couple vehicles. Worked fairly well, but I wouldn't suggest running a msd ignitor (Ie 6a, 6al, etc...) as the extra sparks do nothing but wear out plugs, wires, and dis caps. My 76 turbo 620 had a 6a on it and wore out the carbon buttons in the cap about every 6 months. I later swapped the points dist for a 78 electronic dizzy and wired the BTM in series between the dist. and a 78 620 under dash ignition box to a MSD Blaster coil. All you really need is a good dist. and ignitor. The BTM is not capable of firing a coil by itself. Quote Link to comment
