jesusno2 Posted September 20, 2008 Report Share Posted September 20, 2008 Well I scored the stick shift pedal box for my goon but I'm looking at my car and the auto pedal box and well... Their way different looking the way they mount the steering coloum mounts into the auto pedals and the manual pedal box I don't see where the steering coulum mounts to it?? Do I need a manual steering coulum also for the swap? I was just going to remove all the auto crap from the coulum I have, and use it but now I'm scratching my head? Quote Link to comment
slodat Posted September 20, 2008 Report Share Posted September 20, 2008 You don't even have to swap the "pedal box". You remove the pivot bolt on the Auto brake pedal, and the pedal. Then install the clutch and brake pedals from the manual pedal box in the pedal box still in your dash. They are the same, save for the pedals themselves. You can remove all of the auto transmission shifter linkage from the steering column and install the manual column cover on it. The only difference at that point is a rectangular hole on the steering column's firewall plate. Getting that damn auto shifter linkage out took some effort. I actually removed the steering column from the car to get it done. Removing the steering column is rather easy though. Aside of the little stuff (wiring and such) it mounts at the bottom of the dash and the firewall. Nothing to mess with on the steering box. I left the actual steering shaft in place and slid the column over it. The only thing left is the gas pedal. There's a great thread on the realm with all the info on this. http://www.the510realm.com/phpBB3/viewtopic.php?f=1&t=10202 Quote Link to comment
jesusno2 Posted September 20, 2008 Author Report Share Posted September 20, 2008 seriosly??? man i dont see how the brake pivot looks way different the the auto and also looks like its in a different spot too here are a few pics sorry mine is still in the car hard to get a good picture of it. Quote Link to comment
slodat Posted September 20, 2008 Report Share Posted September 20, 2008 I'm not sure what to tell you. I did this on my car as I described above. As have others I know. I can't make out much from your photos. My advice is, go out there and try it!! Quote Link to comment
jesusno2 Posted September 20, 2008 Author Report Share Posted September 20, 2008 yea i dunno either i busted a damn bolt on the steering where it attaches on the box workin on drilling that bitch out now the 1st pic is a 510 box right? hope so Quote Link to comment
slodat Posted September 20, 2008 Report Share Posted September 20, 2008 I don't know what that pedal setup is from. When I bought my 510, it came with "several 510 pedal setups". Only one of them was 510. The rest were various other shit the previous owner tried to make work. When I figured out which ones were 510, by comparing to another 510, it was really straight forward to get it all together right. Quote Link to comment
mklotz70 Posted September 20, 2008 Report Share Posted September 20, 2008 Might be from a truck...instead of the 510. Quote Link to comment
jesusno2 Posted September 20, 2008 Author Report Share Posted September 20, 2008 yea i dunno the pedal setups look totally different to me i'm workin on try to get my auto pedal box out now so i can compare the too cause somethings a miss i'm guessing the pedal box i got is wrong. Quote Link to comment
jesusno2 Posted September 21, 2008 Author Report Share Posted September 21, 2008 well here they are side buy side looks like i got the wrong one maybe? or a different year 510? Quote Link to comment
datzenmike Posted September 21, 2008 Report Share Posted September 21, 2008 Just checked my '78 620, nope. Here's a set from a 720, closer. http://i138.photobucket.com/albums/q251/datzenmike/720stuffZ24swapLarge.jpg[/img]"] Quote Link to comment
slodat Posted September 21, 2008 Report Share Posted September 21, 2008 His looks like the 620 one you pictured Mike.. Quote Link to comment
jesusno2 Posted September 21, 2008 Author Report Share Posted September 21, 2008 its a car pedal box it has the wrong stlye pedal pads to be a 620 their square shaped not the rectagle shaped truck ones. Quote Link to comment
slodat Posted September 21, 2008 Report Share Posted September 21, 2008 Gotcha. Since you have them both out, why not just get the two pedals from the donor box working in the stock pedal box. It shouldn't be too hard to get it working well. Quote Link to comment
datzenmike Posted September 21, 2008 Report Share Posted September 21, 2008 Sorry, I posted his with my 720 pedals. Check my corrected post. Quote Link to comment
jesusno2 Posted September 21, 2008 Author Report Share Posted September 21, 2008 Gotcha. Since you have them both out, why not just get the two pedals from the donor box working in the stock pedal box. It shouldn't be too hard to get it working well. well im trying to do that now but the brake pedal is quite a bit different the way the springs are and notice the way the auto pivot is? i got these from z therapy so i might run back out later on and see if he's got the correct ones i'm wondering if these were from like a b210 or something Quote Link to comment
jesusno2 Posted September 21, 2008 Author Report Share Posted September 21, 2008 big - on switching the pedals too my auto box has left hand thread piviot bolts and the piviots bolts are also smaller than the other mystery box i have damn it!! Quote Link to comment
jesusno2 Posted September 21, 2008 Author Report Share Posted September 21, 2008 ha ha i just replied back on the 510 realm LOL all quick like a ninja! Quote Link to comment
datzenmike Posted September 21, 2008 Report Share Posted September 21, 2008 I just came from there..... Deja vu!!!!! All over again:lol::lol::lol: (good old Yogi) Quote Link to comment
