SRSANDS Posted September 15, 2008 Report Share Posted September 15, 2008 Today I picked up my clutch assy, flywheel ect. I spent four hours trying to get this tranny up under the car with jacks and slid into the back of my L16...aghhhhh!!!! The L motor originally had an auto tranny on it when I got it. Is there a bushing that may be on the rear of the motor that will not accomodate the new 4 speed shaft? What would be holding the shaft up??? Please help......has anyone did a auto to manual conversion???:confused: Quote Link to comment
SRSANDS Posted September 15, 2008 Author Report Share Posted September 15, 2008 Also, reading a post in the Realm I heard all L16s have a pilot bearing installed.....can anyone confirm this please? ust cant figure out wy the &*^* I CANT GET MY TRANNY LINED UP IN ALL THE WAY INSTALLED!!!!!:mad: Quote Link to comment
420n620 Posted September 15, 2008 Report Share Posted September 15, 2008 if you got a input inlinement tool, use it, cuts down on all the cussing ;) Quote Link to comment
lynchfourtwenty Posted September 22, 2008 Report Share Posted September 22, 2008 i think the autos have a different pilot bearing... i know they do on sr20's.. Quote Link to comment
datsunaholic Posted September 22, 2008 Report Share Posted September 22, 2008 L-series automatics don't have a pilot bushing at all. Used an adaptor plate. Quote Link to comment
datzenmike Posted September 22, 2008 Report Share Posted September 22, 2008 First the the crankshaft will have had a spacer on the end which is only used with an automatic. It has to be removed if installing a standard flywheel A new pilot bushing must be installed in the end of the crankshaft. An automatic will not have had one. Before tightening the pressure plate down the clutch disc must be alligned, usually with a special tool supplied with the new clutch, so that when the tranny is installed the splined input shaft will slide in through the clutch disc and enter the pilot bushing. Quote Link to comment
SRSANDS Posted September 23, 2008 Author Report Share Posted September 23, 2008 Interesting..well here is what found during during my swap journey. First yes you guys you are right about the spacer, had it on then unbolted the tranny and removed it. The pilot bushing is another story. The tranny (4 speed) slid in nice and tight.....the clutch alignment tool was snug also. Not sure if a bushing was in there already or not. I guess I will learn the hard way I suppose the day I fire it up. I did how ever also find the driveline is way too long!!!! Bummer:mad: Quote Link to comment
lynchfourtwenty Posted September 23, 2008 Report Share Posted September 23, 2008 yea, mr. nismopu had put 2 pilot bushings in a ka one time.. didnt work to well.. atleast im pretty sure thats how it went.. Quote Link to comment
SRSANDS Posted September 23, 2008 Author Report Share Posted September 23, 2008 So lynch, in your experience it already had one in it? Was this to a auto to mani conversion as well? Quote Link to comment
lynchfourtwenty Posted September 23, 2008 Report Share Posted September 23, 2008 it was a ka24.. i think he didnt know the engine had a pilot bushing in it an he put one in.. now im not sure but i think it fried the engine or something.. it was a long time ago, i was buzzed.. we had talked about alot of shit that night.. but i know this... if your not sure if theres one already in there.. find out.. or shit may blow up in your face.. better safe then sorry ;) Quote Link to comment
SRSANDS Posted September 23, 2008 Author Report Share Posted September 23, 2008 Shit man dont scare me ha ha all I know is I have had the engine running (in neutral only) and it seems good to go....Guess I wont know till I hook up the drive line huh Quote Link to comment
SRSANDS Posted September 23, 2008 Author Report Share Posted September 23, 2008 Also if anyone knows how would I tell if there isnt one and I have a tranny installed with out it? Would the thing not work....make awful noises or what?????:confused: Quote Link to comment
lynchfourtwenty Posted September 23, 2008 Report Share Posted September 23, 2008 i dont know... well since it was an auto, from what datsun mike says it has no pilot bearing.. so i think your good.. ps, i think that ka siezed at idle... oh another thing.. he forgot an oil pickup tube gromet.. but those might of been different engines Quote Link to comment
SRSANDS Posted September 23, 2008 Author Report Share Posted September 23, 2008 I dont think Im good......I didnt put the one a got in.....it didnt seem to need it.....so I dont really have to worry about having two installed but none at all....aghhhh I will be pissed if I have to tear the tranny out again!:( Quote Link to comment
lynchfourtwenty Posted September 23, 2008 Report Share Posted September 23, 2008 you didnt install one.... take the tranny off an put one in.. seriously.. :( sorry man Quote Link to comment
SRSANDS Posted September 23, 2008 Author Report Share Posted September 23, 2008 Just wish I knew the effects of not having one in and how I could tell. Would be even moe pissed to get it back out and find it has one...:) agghhhh Quote Link to comment
lynchfourtwenty Posted September 23, 2008 Report Share Posted September 23, 2008 well having a Bad one an cause engine shudder and a rough take off.. i think it helps the input shaft sit in the crank nice an comfy.. an im assuming any movement other thing spining around would cause damage Quote Link to comment
datzenmike Posted September 23, 2008 Report Share Posted September 23, 2008 If it was an automatic engine it will not have one in it, so you will have to put one in. OR you can drive it till the tranny lunches and put one in when you take it out to replace it then. Seriously the front of the input shaft needs support. Without the bushing it will flop around in the end of the crank shaft hole and the clutch disc will be off center. This will cause vibration and shuddering during clutch engagement. Here's what it looks like installed: http://i138.photobucket.com/albums/q251/datzenmike/motorpilotbushing005Large.jpg[/img]"] It's just big enough to get the end of your little finger in. They are about $3 at Nissan. I used one for a Z24 in my L20B so they are all the same size if they say they don't have them for L16. Start it in with a hammer and then put a block of wood over it and drive it home. Might be easier if you take the clutch back off. It's made of sintered bronze and is 'soft'. Quote Link to comment
lynchfourtwenty Posted September 23, 2008 Report Share Posted September 23, 2008 theres my new one that came with my kit.. its on the alignment tool Quote Link to comment
SRSANDS Posted September 27, 2008 Author Report Share Posted September 27, 2008 Tore the tranny back out yesterday......just to find that the origonal auto engine that I put the four speed in had already had a pre existing pilot bushing........aghhhhh. When I originally put the tranny in I never installed one so I second guessed my work and had to pull it back out to check. Before I did so I called Nissan and the mech there said I had a 50/50 chance of one being there.......it was. Quote Link to comment
lynchfourtwenty Posted September 27, 2008 Report Share Posted September 27, 2008 well either that or your engine had been replaced by one that came from a manual tranny Quote Link to comment
datzenmike Posted September 28, 2008 Report Share Posted September 28, 2008 It's a bitch going backwards but the alternative is a car that you can't shift properly or vibration that hammers the piss out of the input shaft front bearing. Better safe than sorry. Quote Link to comment
lynchfourtwenty Posted September 28, 2008 Report Share Posted September 28, 2008 It's a bitch going backwards but the alternative is a car that you can't shift properly or vibration that hammers the piss out of the input shaft front bearing. Better safe than sorry. yep always better safe then sorry Quote Link to comment
ariascarlos1990 Posted September 29, 2008 Report Share Posted September 29, 2008 is it hard to replace the clutch fork on a 4speed? Quote Link to comment
lynchfourtwenty Posted September 29, 2008 Report Share Posted September 29, 2008 a list of needs: clutch + brake pedal stuff.. clutch master cylinder all the plumbing from the clutch master cylinder to the clutch slave cylinder clutch slave cylinder (i would buy new for like $7) clutch kit clutch fork throw out bearing sleeve C clip for the shifter flywheel an i would grab the bolts from the clutch thats on the flywheel you get to save some time also i know you need the tranny mount (unless the old one interchanges?) and cross member (unless the old one works) im sure someone can clerify that for us.. is there anything i missed guys? all that stuff should be pretty cheap... its the work involved that sucks oh an hey im not sure if your talkin about your truck or your buddys, but if your just replacing a clutch fork, i think you have to take the tranny off the engine.. i didnt try removing my clutch fork while the tranny was still in the truck.. or the 280zx either.. Quote Link to comment
